November 10, 20204 yr comment_610016 On 11/10/2020 at 1:32 AM, siteunseen said: I found my receipt and it was $20.07 in 2018, each. So $53 isn't as crazy as I thought. So 2 years is a 50% increase... Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610016 Share on other sites More sharing options...
November 10, 20204 yr comment_610023 On 11/9/2020 at 8:32 PM, SteveJ said: creating a jig to heat and mold the hose into shape. I did that a number of years ago. Back before I started taking pictures of stuff like that. My "jig" was a piece of coat hanger wire that was bent into the desired shape (over-bent actually to account for spring-back), and my "heat" was a toaster oven. Worked pretty well. I did some parts out of Viton and some others out of neoprene. PSA - Don't burn the Viton or anything else with fluorine in it. Some more detail just to fill out the story... I ran a pair of those tubes on a some round tops for a while and then pulled the round tops off to go back to flat tops. They worked great while on the car. No binding or other issues. However... Just a few days ago (quite coincidently) I was inspecting those round tops and noticed that the rubber tubes were failing. Cracking around where they were expanded onto the nipples at the ends. I don't know why they were failing. It was Viton from McMaster, so it should have been quality material. Maybe I did some damage with the heat. Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610023 Share on other sites More sharing options...
November 10, 20204 yr Author comment_610025 On 11/10/2020 at 2:42 AM, Captain Obvious said: I did that a number of years ago. Back before I started taking pictures of stuff like that. My "jig" was a piece of coat hanger wire that was bent into the desired shape (over-bent actually to account for spring-back), and my "heat" was a toaster oven. Worked pretty well. I did some parts out of Viton and some others out of neoprene. PSA - Don't burn the Viton or anything else with fluorine in it. Some more detail just to fill out the story... I ran a pair of those tubes on a some round tops for a while and then pulled the round tops off to go back to flat tops. They worked great while on the car. No binding or other issues. However... Just a few days ago (quite coincidently) I was inspecting those round tops and noticed that the rubber tubes were failing. Cracking around where they were expanded onto the nipples at the ends. I don't know why they were failing. It was Viton from McMaster, so it should have been quality material. Maybe I did some damage with the heat. Hmm, I could get a cheap toaster oven from Wally-World. Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610025 Share on other sites More sharing options...
November 10, 20204 yr comment_610028 Or you could just use the one in the kitchen when Ms. J isn't looking. Ms. Obvious was distracted by something else while I took the toaster oven outside and did bad things to it. Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610028 Share on other sites More sharing options...
November 10, 20204 yr Author comment_610040 On 11/10/2020 at 1:25 AM, SteveJ said: Thanks. I'll make the inquiry. As far as the other types of hose I'm buying, I am planning on doing some trials on a spare set of carburetors I have to see if the different types have the necessary flexibility as the nozzle moves with the choke. @Mark Maras, Pam at ZTherapy confirmed. part number ZT20 is for the float bowl hoses. Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610040 Share on other sites More sharing options...
November 10, 20204 yr comment_610048 Excellent. The hoses they sell are amazingly limber. I doubt their lines could or would ever cause a nozzle to bind. Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610048 Share on other sites More sharing options...
November 10, 20204 yr comment_610059 On 11/10/2020 at 1:39 AM, Patcon said: So 2 years is a 50% increase... I'm sorry. That's per hose. Oh wow! I just saw that $54 was per hose too. Sorry again Charles. Cliff Edited November 10, 20204 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610059 Share on other sites More sharing options...
November 10, 20204 yr comment_610072 On 11/10/2020 at 4:51 PM, siteunseen said: I'm sorry. That's per hose. Oh wow! I just saw that $54 was per hose too. Sorry again Charles. Cliff Must be a rare Series 1 part, Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610072 Share on other sites More sharing options...
November 10, 20204 yr comment_610080 On 11/10/2020 at 7:10 PM, AK260 said: Must be a rare Series 1 part, A rare parts department. That dealership should be reported to Nissan headquarters. Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610080 Share on other sites More sharing options...
November 12, 20204 yr Author comment_610202 So I went digging through my carburetor parts in my parts storage today. (Something I should have done months ago.) I found some black Helix Racing Products 3/16 ID x 5/16 OD fuel line. At 3/16 ID, it's a tight fit on the float bowls, but it should work. https://www.helixracingproducts.com/316x-3-fuel-line-black https://www.amazon.com/Helix-Racing-Fuel-Line-Black/dp/B000WK5J0Y It did not kink at a bend radius of less than an inch. It's stiffer than the Nissan hoses, so I will put it on a spare set of carburetors to see if it binds the nozzles. It is tolerant to 10% ethanol and is less than $10 for 3 feet. Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610202 Share on other sites More sharing options...
November 12, 20204 yr Author comment_610204 Oh, I also found I had 2 sets of Nissan hoses...in addition to the set I just purchased...And I'm still trying to figure out why I took a camshaft someone offered me...at least I think it was given to me...I don't recall buying a camshaft...or that Helix fuel line (According to Amazon that was 3 years ago.) Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610204 Share on other sites More sharing options...
November 13, 20204 yr comment_610224 Nothing like more options. https://www.aircraftspruce.ca/catalog/pnpages/15-04818.php?gclid=CjwKCAiA17P9BRB2EiwAMvwNyGDVuhht0dypa-XwCNqz7pVIJ_WSV9hDGVqKnMOl-WcpRjx2K9uCiRoCFJUQAvD_BwE Gotta trust an air craft supplier would sell hose that is fuel worthy. Been studying fuel tubing. Seems Viton tubing is getting the nod. One description. https://www.new-line.com/hose/tubing/viton-tubing/viton-rubber-tubing Edited November 13, 20204 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/64690-dont-buy-this-from-z-car-depot/?&page=3#findComment-610224 Share on other sites More sharing options...
