Hi,
I'm looking for a picture of the original/factory battery cables + and -) for the 240Z.
I tried to find this information on internet but every cars i found have different cables...
Also, cables are the same for all years, or they are different between series ?
Thank you for your help.
https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/
Finally dawned on me what that black blob is on the positive cable. It a rubber cover for the terminal.
Now I have find some that fit the terminals I bought to do this right(er).
I had a set of cables that the "blobs" were still on, but the ends were replaced with straight generic ones. This is what I did to make them more right(er). I used the covers as a mold.
That is really interesting, great idea!
Here are some pictures of the original cables from my 7/70 240Z. @240dkw Hey Dan, I thought that only the positive terminal connector that the "blob" and the negative one was uncovered.
Negative:
Positive:
I realized I have one good original negative cable on the new to me 71 I just picked up.
Now “we” need one of those original blobs to use to make reproduction blobs....
I’ve taken detailed measurements of the cable, lugs, wires etc. Finding the very heavy lugs that Nissan used is going to be a challenge in todays cheap crap marketplace. The big cable lug is a brass or copper monster made with 2mm thick metal and has a lovely crimped connection done with a serious tool.
Edited by zKars
