Chrome trim install
Wally
Does anybody have a video showing how to install chrome trim around hatch and windshield? Or any instructions or tools i need.
Also, does anyone have a source for replacement pieces? Stainless is fine...just not wanting to pay $400 for one set...seems too high
To clarify a bit, all of this trim is stainless steel - not chromed steel. The same goes for the drip rails. The only tool you should need for the windshield and hatch trim is a hard nylon tool for auto trim, usually found at most auto supply stores. The rubber seal has a shallow U-shaped channel for the trim. Place one edge of a trim piece into the channel and under the lip. Use the nylon tool to raise the opposite lip and allow the trim to fit into place. Run the tool along the length of trim and lip to complete the install. Be careful in handling the trim as it can easily bend. Don't force anything.
