Anyone know of a supplier for the 4 pieces of rubber trim (2 per bin) that keep the tool bin lids from rattling when closed. Mine are missing. I'm sure some basic trim could be ordered and cut to fit. Just wondering if anyone knows of a vendor that carries the edge trim or a size that has worked well.
https://www.classiczcars.com/forums/topic/64748-tool-bin-trim/
They are about 10 “ long, and 1/2” wide.
The underside is a bit thinner than the top face.
The slit is well under a 1/32 “ pretty close to a tight fit on the sheet metal.
The bend is formed by cutting out a pie wedge and re-gluing or so it seems. There is a distinct cut there.
Edited by zKars
