Posted November 21, 20204 yr comment_610810 Hello everyone I was wondering if anyone could help me out her. I have a 1972 240z that I'm planning on installing a 1982 280zx close ratio transmission with an R200 out of a 1988 SS 300zx VLSD dif. My question is and probably a few folks have asked this before is what drive shaft or propeller can I use? My car already has a t5 transmission from a 280zx turbo and what looks to be an R180 or R200. I does have the half shafts... Any help will be highly appreciated. Edited November 21, 20204 yr by L.Flores Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/ Share on other sites More sharing options...
November 21, 20204 yr comment_610818 About half way down they talk about driveshafts and where to get one. https://www.datsunzgarage.us/borg/ Powertrain Industries Eh, that doesn't come up on mine. Too old I guess? Edited November 21, 20204 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610818 Share on other sites More sharing options...
November 21, 20204 yr comment_610821 Do you have the correct halfshafts out of the 88' car? Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610821 Share on other sites More sharing options...
November 21, 20204 yr Author comment_610823 Yes, the rear diff is complete and done. I have the yoke with the drive shaft for the fs5w71b 1982 280zx transmission (all from the same car ) and I bought the flange for the r200 1988 ss dif (separate). What I was thinking on doing is remove the flange from the 280zx and replace it with the r200 flange. But they are not serviceable. Edited November 21, 20204 yr by L.Flores Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610823 Share on other sites More sharing options...
November 21, 20204 yr comment_610824 My understanding is that the VLSD half-shafts will be too long. The propeller shaft yoke pattern would be the same as any 300ZX I think. You'll need the mustache bar and diff mount if you have an R180 now. There's a bunch on hybridz.org about the VLSD. Not many success stories. It seems simple but ends up difficult and expensive. https://forums.hybridz.org/search/?q=vlsd&quick=1 Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610824 Share on other sites More sharing options...
November 21, 20204 yr comment_610825 5 minutes ago, L.Flores said: What I was thinking on doing is remove the flange from the 280zx and replace it with the r200 flange. The yoke/flanges are not meant to be removed. The u-joints are staked in. There are machine shops that will convert them to removable u-joints but it's not a DIY kind of job. Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610825 Share on other sites More sharing options...
November 21, 20204 yr Author comment_610826 @Zed Head that's what I was afraid of. Oh well I guess I'm going to have it made by a shop. Any recommendations? Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610826 Share on other sites More sharing options...
November 21, 20204 yr comment_610827 Why do you want to replace the T5? It took some work to get that in to a 240Z. Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610827 Share on other sites More sharing options...
November 21, 20204 yr Author comment_610828 @Zed Head the shifter sits up high in the console, and they cut it, (the previous owner). Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610828 Share on other sites More sharing options...
November 21, 20204 yr comment_610829 How to get limited slip in a Z car is one of those things that looks easy but ends up complex. We all want it, but it's hard to get. There are driveshaft shops all over the place. The 4x4 community supports the businesses. Check your local phone book and make some calls. Find one out away from the city and you can probably get it done and balanced for about $100. Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610829 Share on other sites More sharing options...
November 21, 20204 yr Author comment_610830 Thanks a lot for all your help guy's, I very do much appreciate. And will be posting pics on my build with the vlsd. Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610830 Share on other sites More sharing options...
November 21, 20204 yr comment_610831 Zed head is right. It's a lot of trouble. Most people wanting a limited sip dif go for the Subaru R180. That might be an option for you to investigate. Subaru R180 basic requirements: 1.Subaru R180 liimt slip diff. 2. Wolf racing half shafts. 3. The pinion flange from your 240Z R180 fitted to the Subaru R180 4. I think you need to swap the diff covers as well. Long time ago and can't remember the details all too well. Here is a thread about the Subaru R180 conversion. http://www.wolfcreekracing.com/index.php?option=com_content&view=article&id=22&Itemid=31 Edited November 21, 20204 yr by EuroDat Link added Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/#findComment-610831 Share on other sites More sharing options...
