November 21, 20204 yr Author comment_610838 I already rebuild the cv axles, with the new shorter shafts from WHP and got the mustache bar from Arizona Z Car. I know it's a challenge, but one that I'm intended on taking on to make it work. I'm trying to build my Z with has much datsun oem parts to keep it with in the Nissan family. I may sound a bit nostalgic, but I can't se my self doing it with other brand car parts. Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/?&page=2#findComment-610838 Share on other sites More sharing options...
November 21, 20204 yr comment_610840 Good luck. Take a picture of your diff from behind and post it and we'll tell you if it's an R180 or R200. Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/?&page=2#findComment-610840 Share on other sites More sharing options...
November 21, 20204 yr Author comment_610849 I sure will, + I will soon have a T5 for sale once I remove it if anyone is interested. 👍 Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/?&page=2#findComment-610849 Share on other sites More sharing options...
November 21, 20204 yr comment_610858 You'll probably need the 71B transmission mount also, I think that the T5 mount is different. Depends on how the PO shoehorned that T5 in. Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/?&page=2#findComment-610858 Share on other sites More sharing options...
November 21, 20204 yr comment_610859 On 11/21/2020 at 11:43 PM, Zed Head said: You'll probably need the 71B transmission mount also, I think that the T5 mount is different. Depends on how the PO shoehorned that T5 in. How they did it; may be why it sits too high Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/?&page=2#findComment-610859 Share on other sites More sharing options...
June 8, 20214 yr comment_623013 resurrecting this one, when changing the pinion flange will it not mess up the pinion pre-load or if its torqued back to spec will it be ok? Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/?&page=2#findComment-623013 Share on other sites More sharing options...
June 8, 20214 yr comment_623037 On 6/8/2021 at 12:12 PM, arcdef said: resurrecting this one, when changing the pinion flange will it not mess up the pinion pre-load or if its torqued back to spec will it be ok? The preload will need to be checked, and if not to spec, adjusted per the service manual. Link to comment https://www.classiczcars.com/forums/topic/64749-help-72-240z-280zx-cr-transmission-88vlsd-dif-drive-shaft/?&page=2#findComment-623037 Share on other sites More sharing options...
