cgsheen1 Posted November 22, 2020 Share #25 Posted November 22, 2020 I hope these aren't huge - Galaxy S20, best camera I've ever had. See, my chopped off bumper strut is still there... 1 Link to comment Share on other sites More sharing options...
heyitsrama Posted November 22, 2020 Author Share #26 Posted November 22, 2020 It looks like there is a small dimple that needs to be pulled out of the bumper.... does the chrome finish not like betting beat on with a hammer? Maybe can push it from the backside? The mount points seem to be way off ~7in to where the actual supports are. the strut faces are visible from the bottom, if you are laying down in the street looking at the car 😂 Link to comment Share on other sites More sharing options...
cgsheen1 Posted November 22, 2020 Share #27 Posted November 22, 2020 You're correct, chrome doesn't like to be hit - not with a metal hammer. That indent would need to be pushed (pressed - from the backside). Someone skilled might hammer that out but not the way you'd think. I'd advise against trying it yourself (if you need to ask the question, you probably can't complete the task...) Most formed metal likes to go back to it's formed shape unless it's stretched too much. 1 Link to comment Share on other sites More sharing options...
Freez74 Posted November 23, 2020 Share #28 Posted November 23, 2020 Amar, this is what I did with mine. Link to comment Share on other sites More sharing options...
heyitsrama Posted November 23, 2020 Author Share #29 Posted November 23, 2020 @Freez74 is that Allen bolt on the top of the bumper through a hole that you added to the bumper? Link to comment Share on other sites More sharing options...
Freez74 Posted November 23, 2020 Share #30 Posted November 23, 2020 1 hour ago, heyitsrama said: @Freez74 is that Allen bolt on the top of the bumper through a hole that you added to the bumper? Yes, I drilled a hole in the top of the bumper and attached it to the tie-down with a spacer. I thought it was the simplest way to mount the bumper. The ends are secured to one of the threaded holes in the body. Link to comment Share on other sites More sharing options...
