Hi, I’ve been slowly working on restoring a 77 280,  it has the 5 speed with a hole in the bell housing, I found an early 4 speed from a 70-71 for a decent price locally. I was hoping someone more knowledgeable than me can tell me if the 4 speed bell housing would fit the 5 speed before I spend the money.  Thanks!
https://www.classiczcars.com/forums/topic/64771-bellhousing-compatibility/
Not if it is a 70-71 4 speed.  Is there a picture?  The early 4 speeds had the shift lever that hangs off the back of the transmission.  Like the image below.
http://www.carpartsmanual.com/datsun/Z-1969-1978/power-train/transmission-case
http://www.carpartsmanual.com/datsun/Z-1969-1978/power-train/transmission-control
The shifter may interfere with you trans tunnel and console. It does when you go the other way and add a 5 speed to an early car.
ps 4 speeds out here have little or no valve.
Edited by 7tooZ
Added ps
I think that he wants to use the bellhousing only.  Sounded like it has a hole in the front case.
Note to Z with a Z, these cars combine the bellhousing with the front case in the later years.  So no separate bellhousing like a Chevy might have.
Edited by Zed Head
Correct! From what I can tell the bell housing in mine can be separated there appears to be like a spacer or something between it and the back part of the trans, I wouldn’t be messing with the half with the shifter on it, the dark lit photos are my trans, the shot of the whole one is the 4 speed. Thanks for the replies!
Wow never mind i misunderstood what you meant by, the bell housing being one unit, it doesn’t look like it’s going to fit, thanks for the help
Can you show us a picture of the hole?
