What To Look For in Used Differentials (R200)
Muzez
Hi Guys,
Going to look at a used differential this week to pair with a ZX transmission I just pulled. Was trying to think of things to check before buying.
  • Check Diff stamp on ring gears
  • Internal welds
  • Metal on the drain plug
  • Damage to spider or ring gears
  • Play in the pinions that hold the spider gears.
  • Damage to the pinion seal or bearings.
What else am I missing? Thanks to @Zed Head for some initial inspiration here.
1 hour ago, 7tooZ said:
What are you building that you need An R200?
Switching to a 280zx 5 speed and am looking to get the 3.9 R200 since that appears to be the recommendation for best acceleration. Currently set up with a R200 3.54 and a 4 speed
Go on line and use a gearing calculator to speed the effects of different ratios entering the fifth gear ratio of which 5 speed you have. If you have a a .745 and driving on the street you may want a 4:11..
Have you considered a Subaru STI CLSD R180?
Edited by 7tooZ
I think that he already knows about the ratios and is planning to buy a 3.9 to match the 3.062 1st gear in the 5 speed.  Trying to figure out how to evaluate the quality of the 3.9 diff.
Here are some images of welded diffs.  Some people just do a few solid welds, some people go crazy and fill every crevice.
Here's a funny article about the "benefits" of welded diffs.  Those open diffs are unpredictable!
Edited by Zed Head
that looks like it would make turning very difficult. I guess if you  were drag racing this would be helpful. Would really scrub off rubber if you were to turn with a diff modified like this.
They do it for drifting.  It's just a cheap hack, just need a welder and some welding material.  I wonder if anyone has tried JB Weld.  That would be a great JB Weld ad.
Hugely helpful Zed, this is a perfect visual.
