April 7, 20214 yr comment_619333 There should be a very small gap (just enough air for idle) between the butterfly and the carb housing if the linkage is correct and the choke linkage isn't opening the butterfly a bit for cold start. The only way the pistons will lift is by the engine drawing air past the butterflies. Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619333 Share on other sites More sharing options...
April 7, 20214 yr Author comment_619356 Here's a bunch of photos I took last Fall when I did a bunch of engine work (head gasket, seals, etc) PXL_20201201_005333745.mp4 PXL_20201201_005357207.mp4 Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619356 Share on other sites More sharing options...
April 9, 20214 yr comment_619483 A little late to the party, but here is my 2 pennies worth:It can’t be your cam as it’s only affecting 3 cyls not all six. So IMHO it’s definitely fuelling / carb / intake related.The only time my headers have been visibly glowing is when I’ve been heating the car up at night on choke at around 2-2.5k rpm with an AFR of around 12 (so read very rich). The camera does make it look 10x hotter than it was to the naked eye!!!4k is high indeed for a leak but also do we know how advanced your idle timing is? Just advancing the distributor I’ve had the engine at 2k rpm, let alone adding in a leak.Either way, I would focus on the carb serving the bank of 3 not glowing.Good luck, I’m confident you will find something simple soon as the culprit! Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619483 Share on other sites More sharing options...
April 9, 20214 yr comment_619484 @Awk34 can you post pictures of the throttle shaft? Part number 13 and 14 in this diagram. Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619484 Share on other sites More sharing options...
April 9, 20214 yr comment_619485 Holy crap, that's amazing! No photo tricks, photoshop or anything? Just hot as hell and at night? Wow. Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619485 Share on other sites More sharing options...
April 9, 20214 yr comment_619487 I'll get a picture of my ceramic coated ones maybe tomorrow night if it doesn't rain here. I'm going to get both cars out, weather permitting. New oil and valves adjusted. Now to wear the brake pads down and heat the tires up. Big plans for Saturday, if no rain comes around. Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619487 Share on other sites More sharing options...
April 10, 20214 yr Author comment_619498 On 4/9/2021 at 10:16 PM, AK260 said: 4k is high indeed for a leak but also do we know how advanced your idle timing is? Just advancing the distributor I’ve had the engine at 2k rpm, let alone adding in a leak. I haven't retried finding TDC on my new damper, but you can kind of see what's going on here: https://youtu.be/5KwKMwHtFMI?t=45 Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619498 Share on other sites More sharing options...
April 10, 20214 yr Author comment_619499 On 4/9/2021 at 10:35 PM, heyitsrama said: @Awk34 can you post pictures of the throttle shaft? Part number 13 and 14 in this diagram. Here's some photos. As you can see I don't have any of the vacuum diaphragm / valve stuff on the balance tube, and all the barbs are blocked off with caps. Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619499 Share on other sites More sharing options...
April 10, 20214 yr Author comment_619500 Here's a video to help: It shows the front carb when the engine "idles" at 4000 / 3000 RPM. The piston is definitely shooting up, so there has to be a vacuum leak somewhere between the cylinder and the carb, right? I've attached photos of the front (0007) & rear (0010) butterflies. Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619500 Share on other sites More sharing options...
April 10, 20214 yr Author comment_619501 @heyitsrama here's a couple more photos Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619501 Share on other sites More sharing options...
April 10, 20214 yr comment_619502 OK, MEGA dumb question - are you certain both carbs have the depression springs installed on top of their pistons? Also that gap looks a little wide to me - could be just a trick of the camera. I will take a photo of mine later today for comparison. If memory serves, mine look almost completely shut.A vac leak between carb and intake does not make the piston rise - in fact quite the opposite. Air flow THROUGH the carb does.[mention=23570]siteunseen[/mention] - no tricks just the iPhone camera. The CCD being infrared sensitive picks up the hot manifold and makes it look way hotter. To the naked eye it was just a very slight dark red glow / barely visible but enough to make me want to take a photo! Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619502 Share on other sites More sharing options...
April 10, 20214 yr Author comment_619504 @AK260 Yes there are springs on the pistons. Even the gap being a little too open like it might be shouldn't cause a 3000 - 4000 RPM idle, right? Link to comment https://www.classiczcars.com/forums/topic/64813-l28-w-su-carb-intake-manifold-vacuum-leak/?&page=3#findComment-619504 Share on other sites More sharing options...
