Chassis number HS30 - 103276
Trex
I have a chassis number that says 103276 but is a HS30. I have did some search and the last HS30 made was in 1973 with a chassis number 103262.
Anyone have any ideas. I have been told that the last 240Z's that rolled out of the factory had a miss and match parts that came from the 260Z's. Not sure if anyone can confirm this.
The actual cutoff date would have been different for home or export, [especially into the US].
Your number isn't far away from what was quoted, where did you get your info from in the first place?
If it was Zhome, then some of the numbers they quote are a bit "rubbery'as they haven't taken local production into account.
In reality, one would expect a overlap in parts, a case in question is later model 260's imported into Australia, were for all intents a combination of the 280 and what ever was left over and couldn't be used in the US.
Hi Phil,
103305, looks like we are close cousins. Got the info from the S30 club in Japan in one of their monthly issues.
What bugs me is that I have a 260Z dash but an L24 engine. Then again maybe the previous owner had changed it for whatever reason.
But what sparked of the query was when I read a book written about Z's that actually mentioned about the factory putting in bits of 260Z trim in the last 240Z's that rolled of the factory. That got me qurious.
Well for sure the 240Z dash and 260Z dash are interchangeable.
Originally posted by Trex
103305, looks like we are close cousins. Got the info from the S30 club in Japan in one of their monthly issues.*snip*
But what sparked of the query was when I read a book written about Z's that actually mentioned about the factory putting in bits of 260Z trim in the last 240Z's that rolled of the factory. That got me qurious.*snip*
Trex,
Wasn't your car originally a UK-market model? UK-model HS30 production went well into 1974 I think.
Don't know which Japanese site you got the info from ( CLUB S30 or S30 Owners Club? ) but I think there is a possibility that you might have misunderstood what the figures related to. Don't forget that the Japanese domestic HS30 model was discontinued earlier than the UK / Australian models, and they dropped the "H" prefix when they went back to 2 litre engines at the end of 1973.
The last of the UK-model HS30's were well-known for being a bit strange with regard to spec. They featured lots of parts that were later used on the RS30 models ( different inner wings, the thicker suspension legs etc etc ) - so its clear there was a bit of a grey area for a month or two when the model types changed over. I'm sure the Australian models must have been subject to the same conditions, and in reality its probably the case that all of the RHD models got a bit mixed up around this time.
Contrast this with the LHD car situation, which was always a lot more clear cut, easy to understand and well documented..
Alan T.
It would be strange that my 240 has a 240 dash and is a later number than yours with a 260 dash.
My money would be on a PO changing the dash over.
Can anyone beat my car num?
Originally posted by Gav240z
But I have seen alot of Japanese Z's especially those of the ZG nature with the 260z dash.Gav
Gav,
I think they would be late S30's ( post '73 ) or S31's - so they'd be fitted with the later style dash from the Factory. They would look just like the '260Z' dash that the RS30 and RLS30 models got.
If you spot a ZG-lookalike with the later dash then its certain proof that its not a 'real' ZG ( unless of course its had a later dash retro-fitted for some unknown reason.......:cross-eye:)
It can be hard to pin down the age of some of the later Japanese S30 and S31 models, especially when they have been modified.
Alan T.
Alan & Gav,
Well my car actually came from East Malaysia (Sabah/Sarawak). It was owned by ex-royalties who by virtue of their status do not have to have their car registered or taxed. This explains the 4 year lapse of registration from the year of manufacture to the first registered owner.
It does have a 260Z dash inside but and L24 engine which when cross referenced to the original registration card confirms that it is the original engine number. To further add confusion to the issue it has the 260Z tail lights as well.This probably confirms Alan's point of it being a UK market model made during the model type change over.
Alan, I went into the Club S30 site, reading their monthly magazines. Not proficient in Japanese but some of the characters used by the japanese are similar to chinese. Would you know of the differences between the HS30 shell as compared with the RS30 shell. Looking at the two shells the only immediate visible difference would be the rear light panels. You mentioned different inner wings and thicker suspension legs.
All the best
Trex
Trex,
have you checked the main chassis rails. The two main chassis rails on a 240z should stop short by about 6 inches from the rear of the floor pans, if the chassis is late enough and it sounds like it is if you have 260z style tail lights you may have the longer rails that go right to the rear of the floor pans. Also do you have two large rubber plugs under the rear bumper bar
(covering the cut out holes for impact absorbers).
Does your Zed have aircon in the dash as part of the package .
Cheers
Steve:classic:
Zedrally
Does your 240Z have any features that are outwardly different to standard production as we know it for a 240Z delivered in Aus. Did you get hold of your Z as a going concern,competitive club rally car or did you work it up for the dirt yourself.
I don't no of a later HS30 serial in my area ( lower hunter NSW).
Qualifiying statement: I always have an eye open in case one shows up at the right price.
cheers
Steve :classic:
  • Who's Online   2 Members, 0 Anonymous, 543 Guests (See full list)
