Posted December 17, 20204 yr comment_612655 Anyone have experience with Spazstix Ultimate Mirror Chrome (https://www.hobbyrecreationproducts.com/collections/spazstix-ultimate-mirror-chrome)? I have an interior trim part that needs a chrome appearance and I am concerned that this paint will not be durable enough to withstand the fingerprint touching. Thanks for your input. Keith Link to comment https://www.classiczcars.com/forums/topic/64866-spazstix-ultimate-mirror-chrome/ Share on other sites More sharing options...
December 17, 20204 yr comment_612662 Maybe it's just me, but I have never, ever, ever, never seen anything come out of a spray can that even barely resembled chrome. Even if it has "chrome" in the name somewhere. Link to comment https://www.classiczcars.com/forums/topic/64866-spazstix-ultimate-mirror-chrome/#findComment-612662 Share on other sites More sharing options...
December 17, 20204 yr comment_612682 https://www.amazon.ca/Molotow-ONE4ALL-Acrylic-Marker-703-102/dp/B01E7EG3NM/ref=sr_1_1?crid=1RMFWSO5SD0DS&dchild=1&keywords=chrome+paint+pen&qid=1608215841&sprefix=Chrome+paint%2Caps%2C205&sr=8-1 This stuff ain’t bad for doing the “chrome” lines on the console and HCP etc. Link to comment https://www.classiczcars.com/forums/topic/64866-spazstix-ultimate-mirror-chrome/#findComment-612682 Share on other sites More sharing options...
December 17, 20204 yr comment_612686 +1 on the Molotow liquid chrome pen. Link to comment https://www.classiczcars.com/forums/topic/64866-spazstix-ultimate-mirror-chrome/#findComment-612686 Share on other sites More sharing options...
December 18, 20204 yr Author comment_612731 Thanks all. My project is a seat latch assembly that is 3" long. It will not be touched very often, so the finish does not have to be as hard as real chrome. Has anyone used Molotow Burner Chrome Spray Paint https://www.hobbytown.com/molotow-burner-chrome-spray-paint-150ml-mlw443/p823931 Keith Edited December 18, 20204 yr by zed2 Link to comment https://www.classiczcars.com/forums/topic/64866-spazstix-ultimate-mirror-chrome/#findComment-612731 Share on other sites More sharing options...
December 19, 20204 yr comment_612788 I've used Molotow and it works OK for narrow lines but it might not be the best option for a part that requires a wide area since you'll end up with "brush strokes". I also used Rustoleum Bright Coat Chrome and got acceptable results. It required several coats and cannot be clear coated to increase the luster. It is possible to chrome plastic with real chrome by first coating it with a metallic material or to coat it with aluminum that will shine almost like chrome. Here's a discussion that might explain it. I decided to go with paint. https://www.startribune.com/q-how-do-you-chrome-plastic/41432532/ Link to comment https://www.classiczcars.com/forums/topic/64866-spazstix-ultimate-mirror-chrome/#findComment-612788 Share on other sites More sharing options...
