L20b Cody's Goon
Patcon
I sprayed Chrysler Corp Blue engine enamel on a couple of pieces. I’ve read that it’s supposed to be close but I’m not sure.
To me it doesn’t look like it has enough green in it, but if you google the color some do look greener.
Nice block, only the freeze plug just on the right of the oilfilter is a bit outside it's hole.. normally they are just in the hole with the edge of the lid IN the hole.. On a L24-28 they have a edge were the lid sort of clicks in..?  I always use a bit of sealer. (don't know these brass ones i use steel ones with a sort of 85 degrees edge. they catch the edge in the holes..  if you know what the ... i mean haha)
  • 1 month later...
So I have a question. I have heard that the rod bearings can lack sufficient oil because one main bearing feeds two rod bearings. There was a hack I came across to rebore the galley feeding the main larger. They suggested 1/4" but it looks pretty close to that. Thoughts??
20220226_134527_resized.jpg20220226_134521_resized.jpg20220226_134638_resized.jpg20220226_135041_resized.jpg
Considering only the math, increasing the oil passage diameter from 0.239" to 0.250" would increase the cross-section by just under 10%.  I suppose that's worthwhile, but only a Datsun engine expert would know.  It would seem to be a lot of expense for a street-use-only engine.  Have you checked Tom H's book, 'How to Modify your Nissan & Datsun OHC Engine'?
I have the book but have not checked it. I probably should.
I thought I would call Rebello too for his thought, since I need a recommendation on a head gasket too. I'm not sure the standard L20b gasket has a big enough fire ring to cover our punched out cylinders
So spoke to Rebello
We need to use the head gasket from  a Z24. It will need some modification to provide all the water access ports.
On another point, should we Glyptol or not? Is it worth it on a motor that is not an all out effort?
So i went to my local paint shop and had some single stage made up to match an alternator bracket that still had some factory blue on it. Cody got the block all taped up last weekend but ti was too cold. S o I sprayed it this weekend.
20220306_131115_resized.jpg20220306_131119_resized.jpg20220306_131125_resized.jpg20220306_131051_resized.jpg20220306_155548_resized.jpg20220306_155602_resized.jpg20220306_155609_resized.jpg
It's much darker than it looks in the sunlight. Much more like the paint in the can looks. He is planning on working on the rotating assembly next weekend
  • Like 4
  • 2 months later...
  • Who's Online   1 Member, 0 Anonymous, 610 Guests (See full list)
