December 24, 20204 yr Author comment_613199 Well, I have the terminals and connectors. They look like they should work. I ordered 3 sets of 7 pin connectors and 20 male/female terminals. Link to comment https://www.classiczcars.com/forums/topic/64880-identify-280z-terminal-type/?&page=2#findComment-613199 Share on other sites More sharing options...
December 25, 20204 yr comment_613272 Awesome. Glad they were the right parts! So I went back through my notes and I've purchased from Digi-key, Newark, Onlinecomponents, but never Mouser. I'm assuming I didn't go through the effort to set up an acct there, but it seems like maybe I should. Link to comment https://www.classiczcars.com/forums/topic/64880-identify-280z-terminal-type/?&page=2#findComment-613272 Share on other sites More sharing options...
December 25, 20204 yr Author comment_613275 12 minutes ago, Captain Obvious said: Awesome. Glad they were the right parts! So I went back through my notes and I've purchased from Digi-key, Newark, Onlinecomponents, but never Mouser. I'm assuming I didn't go through the effort to set up an acct there, but it seems like maybe I should. When I found the MIC parts in Google searches that gave links to TE Connectivity (current owner of the design), those pages had links to Mouser. Now if there was only a source for the old Yazaki rectangular connectors. Anyway, I think the 13 pin connectors are available from Mouser, so I guess I could make a plug-and-play relay solution for the 78. I don't think the 77 and earlier used the AMP MIC connectors. Would you happen to know? Now I started working on a CAD version of the 260Z wiring diagram. I'm not as skilled as @wal280z, but I need to teach myself more. Link to comment https://www.classiczcars.com/forums/topic/64880-identify-280z-terminal-type/?&page=2#findComment-613275 Share on other sites More sharing options...
December 26, 20204 yr comment_613308 I don't know what year they started, but my 77 used the MIC mark-1 connectors. Been a while, but if I remember correctly, that's what they used to connect the engine bay harness to other harnesses under the dash? And I think I was messing around with them for the same reason you are. Headlights. Link to comment https://www.classiczcars.com/forums/topic/64880-identify-280z-terminal-type/?&page=2#findComment-613308 Share on other sites More sharing options...
December 26, 20204 yr Author comment_613309 That's where I found them on the 78, and for the headlight relays, I was going to borrow power for the lights from the white/red wires on the ignition relays. Link to comment https://www.classiczcars.com/forums/topic/64880-identify-280z-terminal-type/?&page=2#findComment-613309 Share on other sites More sharing options...
December 26, 20204 yr comment_613317 On 12/24/2020 at 10:35 PM, SteveJ said: When I found the MIC parts in Google searches that gave links to TE Connectivity (current owner of the design), those pages had links to Mouser. Now if there was only a source for the old Yazaki rectangular connectors. Anyway, I think the 13 pin connectors are available from Mouser, so I guess I could make a plug-and-play relay solution for the 78. I don't think the 77 and earlier used the AMP MIC connectors. Would you happen to know TE Connectivity is a good source for finding the detailed drawings and part numbers. Great source. On 12/24/2020 at 10:35 PM, SteveJ said: Now I started working on a CAD version of the 260Z wiring diagram. I'm not as skilled as @wal280z, but I need to teach myself more. Skilled? Thank you for the kind words, but when I did mine is was more like a paint by numbers and trace.... Call me if you get stuck or need some re-configuring of the connector blocks. I didn't think of that when I sent you the drawing. Link to comment https://www.classiczcars.com/forums/topic/64880-identify-280z-terminal-type/?&page=2#findComment-613317 Share on other sites More sharing options...
