Stripped threads
DedZed
So I’m a novice gear head...I replaced the oil sump pan gasket and the previous owner(s) stripped several of the bolts holding the pan to the block. The bolts are M6-1. What method would you recommend to repair? I think coil inserts would work and I could keep the original M6 bolts and torque specs. Tang or no tang? Thank you.
240Z 1970 early series.
A Helicoil insert will do the job quick and easy, the torque spec I think is  about 6lbs so not a lot, using a Time-sert is a better more permanent fix but will cost a little more.  Using either of those methods means removing the oil pan to do the drilling or drilling through the pan lip and using a larger washer then stock.
Helicoils are an excellent method for repairing stripped threads. Be sure and evenly torque the bolts using a torque wrench on reassembly.
What do you mean by tang?
What is a Time-sert? Never heard of it.
45 minutes ago, twofouroh said:
Only a few of the pan bolt holes in L series blocks are blind, so a helicoil isnt going to work in most of them.  Better just to drill and tap those to 8 or TIG and redrill. . .
Why wouldn't a helicoil work in a through hole? I've used them in through holes many times. Loctite red thread locker will keep them in place.
Edited by Racer X
http://www.timesert.com/
It is a permanent fix, you are actually replacing the threads. It also has a self locking expansion lip at the bottom, very well engineered.  I'm sure there must be some youtube videos of them.  A Helicoil is better than nothing but it's a temporary fix because they are so easy to dislodge.
  • Like 3
  • 10 months later...
I just came across this video with what seems to be an unbiased comparison of helicoils, timeserts and key locking type inserts. It's very long but shows some interesting results. I won't spoil it for you. Lol
Cheers, Mike
Edited by CanTechZ
