Posted January 26, 20214 yr comment_615065 Hey does anyone know if a bad water temperature sensor would cause a 1978 280z to not start Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64994-help/ Share on other sites More sharing options...
January 26, 20214 yr comment_615066 Hey @silentbug I think there are already people trying to help you out in the thread you posted earlier; Try to keep your issues contained to one thread so people can see what you have tried, its easier to get help that way. Often when people start opening up multiple threads, and DONT follow the instructions/discussions that are being held within the topics they start, the thread dies out and people stop posting help. I think ZedHead and Steve were walking you through some stuff to test out, I would listen to what they have to say, they are very well informed individuals and have helped lots of people get their 280z fuel injection system figured out, they are not wasting your time and their time trying to help. You will need a multimeter to figure out the EFI system, and YES its possible that the water temp sensor is messing with the system. https://www.amazon.com/AstroAI-Digital-Multimeter-Voltage-Tester/dp/B01ISAMUA6/ref=sr_1_5?dchild=1&keywords=multimeter&qid=1611644234&sr=8-5 Link to comment https://www.classiczcars.com/forums/topic/64994-help/#findComment-615066 Share on other sites More sharing options...
January 26, 20214 yr Author comment_615077 Ok thank you I’ll stick with the other post Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64994-help/#findComment-615077 Share on other sites More sharing options...
January 26, 20214 yr comment_615083 Good luck! EFI can be tricky! Be methodical and write things down! Link to comment https://www.classiczcars.com/forums/topic/64994-help/#findComment-615083 Share on other sites More sharing options...
