February 1, 20214 yr comment_615402 5 hours ago, z8987 said: Sacramento Ca, where are you? Sent from my iPhone using Tapatalk Arlington, Washington. Shipping would add significantly to the cost. Too bad you aren’t closer, I could help you out. Dave Rebello is in Antioch, not far from you. Give him a call. Just make sure they detail the valve springs. ( you can tell him I said that too, as it was one of his engines that I mentioned earlier) Edited February 1, 20214 yr by Racer X Link to comment https://www.classiczcars.com/forums/topic/64997-local-engine-builder/?&page=3#findComment-615402 Share on other sites More sharing options...
February 1, 20214 yr Author comment_615403 Arlington, Washington. Shipping would add significantly to the cost. Too bad you aren’t closer, I could help you out. Dave Rebello is in Antioch, not far from you. Give him a call. Just make sure they detail the valve springs. ( you can tell him I said that too, as it was one of his engines that I mentioned earlier) Number for Dave Rebello? Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64997-local-engine-builder/?&page=3#findComment-615403 Share on other sites More sharing options...
February 1, 20214 yr Author comment_615404 Number for Dave Rebello? Sent from my iPhone using TapatalkFound it. He’s close to me. That’s exciting. Looks like he knows a thing or two about Z’sSent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64997-local-engine-builder/?&page=3#findComment-615404 Share on other sites More sharing options...
February 1, 20214 yr comment_615405 I can't find it too quick but somebody sold a Rebello motor on here a year or so ago for $2,000 if I remember right. It sold in maybe one day. That's a steal price. Quick google search and you'll read a lot of high HPs and positive comments on Dave Rebello. That 2.7 "purists" motor sounds good to me. https://www.google.com/search?client=ms-android-americamovil-us-revc&source=android-home&source=hp&ei=l30YYNjfOKGZ_Qbl9bfACw&q=dave+Rebello+classiczcars.com+&oq=dave+Rebello+classiczcars.com+&gs_lcp=ChFtb2JpbGUtZ3dzLXdpei1ocBADOgIIKToHCCkQChCgAToFCCkQsQM6BwgpELEDEEM6CAgAEOoCEI8BOgsILhCxAxCDARCTAjoICAAQsQMQgwE6CwguELEDEMcBEKMCOgUILhCxAzoICC4QxwEQowI6DgguELEDEMcBEKMCEJMCOgIILjoFCAAQsQM6CAguELEDEIMBOgUIABDJAzoFCAAQkgM6CAguELEDEJMCOgIIADoECC4QCjoECAAQCjoKCC4QxwEQrwEQCjoGCAAQFhAeOgUIIRCrAjoFCCEQoAFQ1zpYuJABYOecAWgBcAB4AYAB2QGIAbETkgEGMC4xMy4ymAEAoAEBsAEeuAEC&sclient=mobile-gws-wiz-hp Link to comment https://www.classiczcars.com/forums/topic/64997-local-engine-builder/?&page=3#findComment-615405 Share on other sites More sharing options...
February 1, 20214 yr comment_615407 1 hour ago, z8987 said: Found it. He’s close to me. That’s exciting. Looks like he knows a thing or two about Z’s Sent from my iPhone using Tapatalk I sent him an E31 head some years back to mill, put larger valves and seats in, port and flow. My only complaint was the coolant passages were full of chips from the machine work, and they didn’t detail the valve springs. I called to try and address it and the response was I could ship it back at my expense, and he would take a look at it. I just disassembled it, cleaned it out and detailed the springs myself. Edited February 1, 20214 yr by Racer X Link to comment https://www.classiczcars.com/forums/topic/64997-local-engine-builder/?&page=3#findComment-615407 Share on other sites More sharing options...
February 1, 20214 yr Author comment_615408 I sent him an E31 head some years back to mill, put larger valves and seats in, port and flow. My only complaint was the coolant passages were full of chips from the machine work, and they didn’t detail the valve springs. I called to try and address it and the response was I could ship it back at my expense, and he would take a look at it. I just disassembled it, cleaned it out and detailed the springs myself. That’s too bad. I just got off the phone with him. Sounds like a great guySent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64997-local-engine-builder/?&page=3#findComment-615408 Share on other sites More sharing options...
February 2, 20214 yr comment_615421 3 hours ago, z8987 said: That’s too bad. I just got off the phone with him. Sounds like a great guy Sent from my iPhone using Tapatalk He has a great reputation, and has built lots of championship winning engines. The head he did for me has been on two bottom ends I've built, I won a regional championship in 1997 with it, and it is sitting on my bench waiting for another engine to get paired up with. Link to comment https://www.classiczcars.com/forums/topic/64997-local-engine-builder/?&page=3#findComment-615421 Share on other sites More sharing options...
February 2, 20214 yr Author comment_615424 I’m keeping my series 1 stock. After talking with Dave I’m considering having him stroke it. Keeping the SU’s. Any thoughts on this? Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64997-local-engine-builder/?&page=3#findComment-615424 Share on other sites More sharing options...
