On 2/7/2021 at 12:17 PM, Av8ferg said:
It’s a harmless hobby.
Yep, it is.  Seems the problem is it takes TIME and MONEY away from doing things together, you know, like  used to do.😁
After "parking" my car for 27 years, I just want to finish it.  I am highly focused, and typically singled-minded when I have a major goal.  That works well for getting shizel done, but does have a cost with relationships.
Oh well, life is a balancing act.
Everything in life is a about balance. When we allow things in life to get out of balance negative stuff starts to happen. Whether it’s our diet, drinking, spending or any litany of things we suffer with imbalance .
Sure the hobby takes away time from relationships but we all need an outlet, we all need white space from the people in our close circles. I generally don’t work on my car when my kids or wife are home. I find time when they’re doing their things. School or work or their hobbies....the key is to know when it’s time and not time.
On 2/7/2021 at 9:17 AM, Av8ferg said:
[quote]Wait until she finds out it doesn’t even have cup holders. [/quote]
Every car I own has a cup holder.
Right here:
Edited by Racer X
Stoopit forum software!!!
I’ve been working on my air cleaner box for a bit and finally got to paint.
I didn’t get many good before pics. This one is shortly after starting stripping.
The box was more rusty than the cover. I’m “probably” not going to go as crazy on it as I did the lid, but I tend to not be content until things look satisfactory to me.
After some primer and some sanding.
After some more primer and a couple coats of paint.
Wasn’t that pleased with it so I wet sanded it and covered it again a week later.
A little better, but I may hit it again after another block sanding in the future.
I did paint the box too and the charcoal/evap canister bracket. The box is very pitted but mostly where you can’t see it. I did fill some areas that can be seen.
Thanks!
Yeah, it’s the lighting or however my phone decides to pick it up.
It’s done with Duplicolor Pontiac Blue Engine Enamel DE1610. Not sure how close it really is, but I think it’s good enough. Not as dark as the dark pics and doesn’t seem as light as the light ones, ha.
http://www.xenonzcar.com/s30/enginepaint.html
