OK couple of questions
1. on the bottom pulley where my hand is there are 3 slots.... is only 1 of them used?
2. In the other photo i have a black bracket with pulley laying on the engine hoist leg. Whats this pulley for and does it mount right below the fuel pump and above the alternator?
thanks
https://www.classiczcars.com/forums/topic/65038-belts-alternator/
1. Yes, you can get away with only using 1 of them, the others can be used for smog pumps or AC compressors.
2. that looks like its an AC tension pulley, but i could be wrong.
