Zcardepot Header Experience?
Vorticity
Maybe he builds them to order and he got lazy on his picture taking.  His BMW headers seem to be fully welded.  Doesn't seem pleasant to deal with, whatever is going on.  Just surprising that people who should know what's important don't show what's important.
https://www.ebay.co.uk/itm/Top-End-BMW-2002-Shorty-E10-Exhaust-Header/164146687745?hash=item2637e7af01:g:xLsAAOSwFnFV8bQ3
The reason that I have read about is a fully welded runner onto the flange tends to crack easier where as a flange that is pinning the flattend end of runner to the exhaust port doesn't. The small tack welds on the outside of the flange hold it all together but allow the different expansion rates to coexist without cracking.
It does make some sense but then I've had fully welded headers that have never had a problem with cracking.  Maybe on a race car where there would be more extremes it would be different?
Any headers part-welded onto the flange have been so done to keep costs down.
If you have the opportunity to buy headers with matching ports do so.
A 6-1 will work, a 6-2 will work better*.....better still with longer twin secondary pipes joining to 1x at the rear of the gearbox and not before the firewall.
All said, of the least expensive headers on the market - the coated MSA 6-2 is the best value : https://www.thezstore.com/page/TZS/PROD/classic19d/15-6001CH
Please note that its' 1.5" primary pipes have a much smaller inner diameter than other after-market headers although plenty big enough for a stock or near stock street engine.
*for a street engine, what one needs to release is torque, not top-end power. A 6-2 will do this best and torque is what we use for each gear change and acceleration ; ask yourself how frequently you max out the revs to obtain max power ?
  • Like 4
  • 1 month later...
  • Who's Online   2 Members, 0 Anonymous, 706 Guests (See full list)
