Its not about cost. Its about local availability. I paid 21 for this master clutch and 15 for the slave. I hope it lasts a couple of years. I only use this car on sundays.
  • 1 year later...
Similar issue happened this morning in my '71 240Z.  Clutch pedal goes to the floor easily, all gears grind if I try to engage.
A suggestion: when you fill the clutch circuit, use DOT5 silicone fluid.  It works great and doesn't draw moisture so the slave cylinder won't get corroded.  I learned this the hard way.
 Pull the rubber boots back and take a peek under boots on the clutch master and slave cylinder. If there is brake fluid in the boot, you've found the leaky cylinder. Over the years I've found that if I replaced the leaking cylinder and not the other, within a year I was replacing the other cylinder because of a leak. I recommend replacing both cylinders at the same time.
If you need to drive it somewhere... Shut off the engine, put it in 1st gear and start the engine with it in gear. Shifting is fairly easy, let off the gas a little and it should be easy to pull out of gear and as the RPM's drop you should be able to slide it into the next gear without grinding. When you need to stop put it in neutral and stop. Shut of the engine and repeat above to go again.
 Great advice. I've done it more than once. If however you decide to try this method to back up, leave a lot of space behind you.
Not practical for a 10 mile drive in mixed freeway and urban/suburban streets, but suitable in an emergency.  Had a flatbed tow my car to Z Car Garage.  Bleeding didn't help so we replaced the clutch master/slave cylinders, the line, the clevis pin.  ZCG did the work on the spot, while I waited.  Recommended!
It works.. but you have a chance on a bended axle in your starter.. (as it has to "start" the whole car now..)  I would use it when on a traintrack crossing.. and nothing worked.. to get off it hahaha...
