jonbill Posted March 5, 2021 Share #13 Posted March 5, 2021 20 minutes ago, TomoHawk said: The only place you can accurately measure the air-to-fuel ratio of what gnes into the cylinders is to put a sensor into the intake manifold. Even more precisely, is to have a sensor near each intake port. Having an o-2 sensor (whatever "0-2" means) only measures o-2 in that partuicular spot What sensor can you put in the inlet tract to measure the air/fuel ratio? Link to comment Share on other sites More sharing options...
heyitsrama Posted March 5, 2021 Share #14 Posted March 5, 2021 @chaseincats not to derail the discussion y’all are having, but what kind of measurements do you get? Link to comment Share on other sites More sharing options...
240260280 Posted March 5, 2021 Share #15 Posted March 5, 2021 Here is a very useful graph: Measurement: Same Car Red O2 measurement at manifold Blue O2 measurement at exhaust pipe. Findings: Both read the same value for steady state. Dilution reduces resolution of transients at exhaust pipe. 3 Link to comment Share on other sites More sharing options...
AK260 Posted March 5, 2021 Share #16 Posted March 5, 2021 Mine sits at about ~10.3 with the choke on to warm up, 12 on idle after warming up, 14.5-14.8 on load ~3k RPM, 14.7-14.9 @ 80-100MPH, cant get it over 100 it pops out of gear [emoji20] Running SM needles on a 4screw SU. Those AFRs are perfect for part throttle / cruising. You may wish to reconsider the mix if your definition of load is WOT. My idle is also pretty rich at about 12.5-12.8 - which makes for a cooler idling engine but boy does it smell ;)For comparison, my AFR on WOT dips to a crazy low 10.5 at 3.1krpm where there is a reversion torque hole and then sits doggedly between 12.5-12.8 from 3.5k to the red line. 1 Link to comment Share on other sites More sharing options...
heyitsrama Posted March 5, 2021 Share #17 Posted March 5, 2021 (edited) @AK260 actually this is something that I would like to do, it needs more “ooofm” when you hammer the throttle. Perhaps dropping the jet down 1/6 of a turn at a time? Or do I have to start messing with needle profiles? @240260280 I want to match that graph, what kind of setup are you running? 😬 Edited March 5, 2021 by heyitsrama Link to comment Share on other sites More sharing options...
AK260 Posted March 5, 2021 Share #18 Posted March 5, 2021 [mention=32052]AK260[/mention] actually this is something that I would like to do, it needs more “ooofm” when you hammer the throttle. Perhaps dropping the jet down 1/6 of a turn at a time? Or do I have to start messing with needle profiles? [mention=31602]240260280[/mention] I want to match that graph, what kind of setup are you running? [emoji51]Well chap, the best tuning tool I have EVER used is the AFR gauge - going down 1/6 or 1/3 at a time on the side of the road and hammering up and down the same piece of road is a good way to go. The car will feel more responsive and lively when you have it right.At 14ish AFR on WOT you’re definitely too lean for good power. I have found anything between 11.5-13.2 can work well but 12.2-13 is ideal.You will find that once you get it in this zone, your water temps drop too. Also you may aim for the higher end of that zone for better economy or a better compromise on idle AFR etc.I too was running SM needles that felt a little lean on my modified engine. The jets were very far down. Once they were modified by a tuner on the rolling road, the car absolutely came to life!!! I didn’t like their work so I set about experimenting and found MC needles with 2oz (stock) springs have superb throttle response and good all round AFRs.The tinkering was hampered by C19 and will pick up again this summer - but here is my thread on it so far in case you are bored ....https://zclub.net/community/index.php?threads/su-carbs-will-work-perfectly-on-my-modified-l28-and-give-dcoes-a-run-for-their-money.25839/What is your engine spec? Link to comment Share on other sites More sharing options...
chaseincats Posted March 6, 2021 Author Share #19 Posted March 6, 2021 (edited) So I just finished wiring the gauge and will be taking it in tomorrow morning to have the o2 sensor bung welded in then I'll drive back and give you guys some numbers. Stock l28 with EFI. I pretty much followed this guys video (even got the same gauge): https://www.youtube.com/watch?v=XS_f2ciKVqo&t=9s Edited March 6, 2021 by chaseincats 1 Link to comment Share on other sites More sharing options...
chaseincats Posted March 6, 2021 Author Share #20 Posted March 6, 2021 (edited) Ok gang, here come the numbers on my stock EFI system as-is: Idle: 13.4 2500 rpm shift points: ~13.2 WOT: 12.4 Highway cruise: TBD (will update tonight) NOTE: This is without the high altitude switch on (when enabled it seems to lean the mixture out 1 full point) Changes made: leaned idle to low 15s, will adjust big drive mix gear at a later time. @AK260 Is that chart (except for the ones labeled WOT) for idle, or highway cruise (4k-4500rpm)? Edited March 6, 2021 by chaseincats Link to comment Share on other sites More sharing options...
jonbill Posted March 6, 2021 Share #21 Posted March 6, 2021 1 hour ago, chaseincats said: Ok gang, here come the numbers on my stock EFI system as-is: Idle: 13.4 2500 rpm shift points: ~13.2 WOT: 12.4 Highway cruise: TBD (will update tonight) NOTE: This is without the high altitude switch on (when enabled it seems to lean the mixture out 1 full point) Changes made: leaned idle to low 15s, will adjust big drive mix gear at a later time. @AK260 Is that chart (except for the ones labeled WOT) for idle, or highway cruise (4k-4500rpm)? TBH those values look pretty good. I wouldn't go leaner than low 14s at idle. Mid 14s at cruise, no need to go leaner unless you're doing big mileage and want to save a few pennies. 1 Link to comment Share on other sites More sharing options...
chaseincats Posted March 6, 2021 Author Share #22 Posted March 6, 2021 2 minutes ago, jonbill said: TBH those values look pretty good. I wouldn't go leaner than low 14s at idle. Mid 14s at cruise, no need to go leaner unless you're doing big mileage and want to save a few pennies. So you're thinking I should lean out the drive gear and re-richen the idle a bit? I thought the idle was supposed to be leaner than cruise, no? I did notice after leaning the idle out that the car off the line is a lot zippier. I almost smacked my garage door when turning away from my house the first time I drove it post-tune lol. Link to comment Share on other sites More sharing options...
jonbill Posted March 6, 2021 Share #23 Posted March 6, 2021 I would yes, unless you've got to get through a strict emission test, in which case aim for 14.7 at idle. Modern OEMs run leanest at cruise - lots of ignition advance and a little leaner than 14.7. Link to comment Share on other sites More sharing options...
chaseincats Posted March 6, 2021 Author Share #24 Posted March 6, 2021 1 minute ago, jonbill said: I would yes, unless you've got to get through a strict emission test, in which case aim for 14.7 at idle. Modern OEMs run leanest at cruise - lots of ignition advance and a little leaner than 14.7. What rpm would you say is 'cruise' so I can have the pedal held when tuning it? Link to comment Share on other sites More sharing options...
