Well this is the point where you need to decide whether to continue with the OEM EFI or go programmable .
Yes the 123 ignition basically drops in with some wiring to adapt to factory wiring . It’s 600$ approx. You should watch a you tube video on it .
Same amount of money would get you a basic programmable  ECU like a Megasquirt . Then you would have full control of the engine with many options - ESPECIALLY if you want to modify your engine one day .
Well, the whole point of this thread was learning how to tune the stock system but thanks for letting me know.
Its not about absorbing heat, its about keeping the tip of the spark plug at the right temperature to keep it clean but not burn. When the cylinder temperatures are higher (higher compression, different fuels etc) then the plug tip needs to be more shrouded to keep it a bit cooler.
I.e. a hot plug doesn't run hotter than a cold plug, they are all meant run at the same temp. A cold plug needs a hotter cylinder to keep it at the target temperature.
So if you were convinced that you change in AFRs was resulting in hotter cylinder temperatures, then you might fit a 7 plug. And then if you discover it gets fouled you could go back to a 6.
If you buy the cheap standard plugs, thats not painful.
Wot he said!!!
Here’s the full explanation from the link I shared above
The engine is absolutely running leaner which adds heat.  The TPS on a stock car basically keeps the car in WOT configuration at almost all pedal pressure we discovered earlier on in this thread, and since we bent that pin out a bit, the car will be in cruise mode longer (highway speed).  So maybe a 7 would be a good test in this case?
