Posted March 6, 20214 yr comment_617240 I am trying to figure out what coil to use. The 78 doesn’t have the ballast resistor so is it the 1.5ohm or 3.0ohm I am looking at the pertronix coils. The verbiage is confusing because there is no stock ballast resistor Factory Electronic Ignition:1974 and later Z's with original ignition should use this 1.5 Ohm coil as opposed to the PerTronix 3.0 Ohm coil, and also should retain the stock ballast resistor. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65139-78-280z-ignition-coil/ Share on other sites More sharing options...
March 6, 20214 yr comment_617244 I learned that the zx e12-80 distributor uses the 1.5 ohm coil when I installed one on my 240. I assume the electronic distributor use 1.5 coils. The early points one use 3.0. Brighter minds will tell us soon. It's Saturday. Link to comment https://www.classiczcars.com/forums/topic/65139-78-280z-ignition-coil/#findComment-617244 Share on other sites More sharing options...
March 8, 20214 yr Author comment_617307 Any brighter minds out there ? Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65139-78-280z-ignition-coil/#findComment-617307 Share on other sites More sharing options...
March 8, 20214 yr comment_617314 What ignition system? The module. Not clear. If it's Pertronix, there are two types. Link to comment https://www.classiczcars.com/forums/topic/65139-78-280z-ignition-coil/#findComment-617314 Share on other sites More sharing options...
March 8, 20214 yr Author comment_617315 I am using all stock ignition for a 78. And looking at these coils https://www.thezstore.com/page/TZS/CTGY/classic11f02Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65139-78-280z-ignition-coil/#findComment-617315 Share on other sites More sharing options...
March 8, 20214 yr comment_617325 The 1978 ignition system uses a 0.84 - 1.02 coil. It's in the FSM. No reason to vary from that, it's a "high-energy" wide spark plug gap system. Looks like everyone is consolidating on the label, and not the specs. Those flames look cool. OReilly has one that is supposed to meet spec. but they don't show the spec. Rockauto is am option. They have an NGK coil. Coils are a basic electrical component. The flames and colors really don't add much. A 1.5 ohm might actually give you less spark power than a 1.0. I like to stick with matched components if I can. https://www.oreillyauto.com/detail/b/import-direct-ignition-4488/ignition---tune-up-16776/ignition-coils-19690/ignition-coil-12493/90c5da72ae86/import-direct-ignition-coil/230257/4578740/1978/nissan/280z?q=ignition+coil&pos=0 https://www.rockauto.com/en/catalog/nissan,1978,280z,2.8l+l6,1209260,ignition,ignition+coil,7060 Link to comment https://www.classiczcars.com/forums/topic/65139-78-280z-ignition-coil/#findComment-617325 Share on other sites More sharing options...
March 8, 20214 yr Author comment_617331 That’s excellent now that I know the range I know what to shop forSent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65139-78-280z-ignition-coil/#findComment-617331 Share on other sites More sharing options...
