 It appears the large end is a crushed tube. Stretching my imagination and making several assumptions (it was a tube, it's not an orig. part), it looks like something I'd fabricate to extend and anchor a cowl drain tube inside the fender.
I was going to guess “drain” as well. Is the flattened wide thing rubber or metal? May be an add or user replacement to whatever was on there before. I have never ever seen these.
Thanks guys. I appreate your help. siteunseen has the best answer. Yes a drain of some sort. Yes the wide part is rubber that is flatened. The clamp is most definitetly not OE. The hose is quite old however. Just thought I would ask, Maybe it was one of those unobtainables. Maybe not!
