Richie G Posted March 15, 2021 Author Share #13 Posted March 15, 2021 Thanks Mark I'll give that a try. So no pumping pre start or part of the start? The guy that dropped it off says pump her three times and skip the choke. I was like ummm no I don't so. Link to comment Share on other sites More sharing options...
S30Driver Posted March 15, 2021 Share #14 Posted March 15, 2021 Beautiful original looking restoration! Safari Gold no less... In your climate, with the carbs dialed in correctly, I would guess it will start with no choke needed. I assume it is warm in your area of California. In any case, you want to use the least amount of choke and its time you can get away with. Nothing like washing the cylinder walls with gas if its left on too long. Link to comment Share on other sites More sharing options...
Patcon Posted March 15, 2021 Share #15 Posted March 15, 2021 Pumping SUs really doesn't help without the starter spinning. There is no accelerator pump in an SU like many classic cars had 1 Link to comment Share on other sites More sharing options...
dutchzcarguy Posted March 15, 2021 Share #16 Posted March 15, 2021 Hé welcome here, you have a very nice car there! One question i got.. Why is the 5'th button, preselect button on your radio green? Never seen that (NOT that i've seen it all hey !!! 😄) ? Have you found your oil leak? I have a 240z i fixed up in 2000 and never leaked oil, i think it's very possible to have a 240z thats bone dry under it.. Link to comment Share on other sites More sharing options...
Mark Maras Posted March 15, 2021 Share #17 Posted March 15, 2021 Most carbs have accelerator pumps that squirt an extra bit of gas to enrich the mixture when one pushes on the gas pedal. Round top SUs don't have an accelerator pump as Charles stated. Try starting it without the choke and if it doesn't start right away gradually give it more choke until it fires. 1 Link to comment Share on other sites More sharing options...
Richie G Posted March 15, 2021 Author Share #18 Posted March 15, 2021 dutch come on man, that's the AWESOME button! 🙂 The guy i bought it from mentioned the radio was shot, probably just an old button he had laying around. I'm also missing the button on the hazard switch and it doesn't work. Mark I'll try that next time i can get her started. It's going to be another rainy day out here 😞 I noticed there's a summer winter valve on the air intake. i downloaded the manual, says over under 60F to use that. Any opinions on where that stands? Link to comment Share on other sites More sharing options...
rcb280z Posted March 15, 2021 Share #19 Posted March 15, 2021 Wow, very nice! I just noticed you're missing a wing nut at the rear of the air filter housing. Link to comment Share on other sites More sharing options...
Racer X Posted March 15, 2021 Share #20 Posted March 15, 2021 (edited) 1 hour ago, Richie G said: I noticed there's a summer winter valve on the air intake. i downloaded the manual, says over under 60F to use that. Any opinions on where that stands? The summer/winter valve directs warm air from the exhaust manifold heat riser when selected for winter to prevent icing in the carburetor throats, blocks that off and directs cooler air from the front when selected for summer. Edited March 15, 2021 by Racer X 1 Link to comment Share on other sites More sharing options...
Patcon Posted March 15, 2021 Share #21 Posted March 15, 2021 Don't get rid of the radio, even if it doesn't work! They are getting quite valuable and there are people out there who rebuild them. Link to comment Share on other sites More sharing options...
