Posted March 16, 20214 yr comment_617921 Hi guys and gals Got my engine and tranny in but lost the mount bolts. Can anyone describe them in a manner that is can describe to a person in a fastener shop ? Thx SB Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/ Share on other sites More sharing options...
March 16, 20214 yr comment_617923 https://forums.hybridz.org/topic/65063-what-size-bolts-do-i-need-for-the-240z-transmission-mount/ https://forums.nicoclub.com/transmission-mount-bolts-spec-t237468.html 10mmx1.25mmx30mm Edited March 16, 20214 yr by heyitsrama Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/#findComment-617923 Share on other sites More sharing options...
March 16, 20214 yr comment_617929 On the transmission mount cross member my 7/70 has M10x1.25 x 25mm long JIS type cap screw with 14mm hex size. Plus lock and flat washers. The actual transmission mount on mine has two M10x1.25 x 25 flanged head cap screw. The head has a larger head, 19mm hex and 28mm OD flange, the flange and head is clipped. Plus lock washer and M10x1.25 Nut, JIS type (14mm hex). These bolts seem a little short, see picture before I removed them. Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/#findComment-617929 Share on other sites More sharing options...
March 16, 20214 yr Author comment_617930 I should have been more specific. I have a 73 built in july 72 it has a cross member with a bushing on each side. The bolts pass through the bushings. They appear to be around 3.5 inches long. Edited March 16, 20214 yr by Sailor Bob Add details Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/#findComment-617930 Share on other sites More sharing options...
March 16, 20214 yr comment_617932 Here is a page from the parts book, I thought I might be able to decode the part number but as of 7/72 the part number is not an NES type, it does show that it will be M12x1.25. Funny the bolt up to 6/72 has an NES part number (08124-27510) that decodes as Hex Head Bolt, Medium Carbon, M12 x 75mm long, zinc plated. Edited March 16, 20214 yr by CanTechZ Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/#findComment-617932 Share on other sites More sharing options...
March 17, 20214 yr Author comment_617935 You nailed it. Thank you very much. And looking at this fiche diagram stirred my memory. I have this on disc somewhere. Either way, i appreciate your effort, i ever get back to chilliwack ill look you up and supply libations Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/#findComment-617935 Share on other sites More sharing options...
March 17, 20214 yr comment_617956 You're very welcome, if you make out here definitely message me and we can sample some local hazy IPA's as well. Cheers, Mike Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/#findComment-617956 Share on other sites More sharing options...
April 10, 20214 yr Author comment_619555 All back where its supposed to be. Fluids next, Rad goes in tomorrow. Not sure why i didnt check the tranny filler plug befor installing. Its solid. Pretty frustrating.. any advise ? Edited April 10, 20214 yr by Sailor Bob Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/#findComment-619555 Share on other sites More sharing options...
April 10, 20214 yr comment_619556 Heat. Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/#findComment-619556 Share on other sites More sharing options...
April 10, 20214 yr Author comment_619557 7 minutes ago, Zed Head said: Heat. Yup Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/#findComment-619557 Share on other sites More sharing options...
April 12, 20214 yr Author comment_619662 No joy. Filled it through the reverse sensor Link to comment https://www.classiczcars.com/forums/topic/65179-transmission-mount-bolts/#findComment-619662 Share on other sites More sharing options...
