Posted March 19, 20214 yr comment_618096 While pressing on a new crank damper, I heard a 'ping' and new it was that damn woodruff key. I pulled the damper back off and sure enough it was gone. I've searched all through there, pulled the seal off, tried digging around with picks and a magnet (although a large magnet on a straight stick, not the best tool for that) to no avail. I'm dreading the thought of having to disassembly the engine again just to get that damn key back. Do you guys know of another way? If it fell into the oil pan, should I just leave it there? Is it possible it fell into one of the oil pump holes? Please Help! Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/ Share on other sites More sharing options...
March 19, 20214 yr comment_618099 It's not going anywhere. Leave it for the next guy. It might end up on your drain plug magnet. https://www.thezstore.com/page/TZS/PROD/10-2163 https://zcardepot.com/products/crankshaft-woodruff-key-oem-240z-260z-280z?gclid=CjwKCAjw9MuCBhBUEiwAbDZ-7isNOClrwtUI2J2DW2XhCmh3NKXlmPE7N6ZD_4dJXtYIMHgVquObfRoC3ycQAvD_BwE&utm_campaign=google shopping&utm_medium=cpc&utm_source=google&variant=19276322832497 Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618099 Share on other sites More sharing options...
March 19, 20214 yr Author comment_618100 It's a relief to hear you say that. Do you have any tips on making sure the next one doesn't fall out when installing the damper? Is it a bad idea to glue it in place? Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618100 Share on other sites More sharing options...
March 19, 20214 yr comment_618105 5 hours ago, Awk34 said: It's a relief to hear you say that. Do you have any tips on making sure the next one doesn't fall out when installing the damper? Is it a bad idea to glue it in place? A dab of wheel bearing grease should keep it in place until you slide the damper on. Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618105 Share on other sites More sharing options...
March 19, 20214 yr comment_618109 Is your oil slinger intact? If you pushed the woodruff key thru into the pan, it would probably destroy the circular metal oil slinger unless you were very lucky and the notch on the oil slinger was perfectly aligned to the key. Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618109 Share on other sites More sharing options...
March 19, 20214 yr comment_618110 7 hours ago, Awk34 said: It's a relief to hear you say that. Do you have any tips on making sure the next one doesn't fall out when installing the damper? Is it a bad idea to glue it in place? Make sure there are no burrs on the damper that might be grabbing the woodruff key as it slides on, lightly go over the edges with a fine file. Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618110 Share on other sites More sharing options...
March 19, 20214 yr comment_618129 7 hours ago, Diseazd said: Is your oil slinger intact? If you pushed the woodruff key thru into the pan, it would probably destroy the circular metal oil slinger unless you were very lucky and the notch on the oil slinger was perfectly aligned to the key. I wonder if the oil slinger is the "metal plate" that somebody was seeing in a recent thread about the woodruff key. He was just trying to replace the seal and ended up with quite a mess. His key was jammed in the keyway at an angle. I've read that some engines didn't come with the slinger and many people just leave it out after working on the engine. Here's the thread -  Edited March 19, 20214 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618129 Share on other sites More sharing options...
March 19, 20214 yr comment_618133 The Honsowetz modify book suggest leaving it out? Don't understand that but did it anyway on my 280. The 240 has one for sure after I researched a liitle better. Â Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618133 Share on other sites More sharing options...
March 19, 20214 yr comment_618135 Interesting....I figured if the factory installed it, so would I. All of the engines I’ve taken apart have had them. Wonder why it’s called an oil slinger?   Here’s one those little suckers! Probably keeps oil off the seal would be my guess. Edited March 19, 20214 yr by Diseazd Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618135 Share on other sites More sharing options...
March 19, 20214 yr comment_618137 I read it slings oil back onto the lower timing chain sprocket, if I remember right. Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618137 Share on other sites More sharing options...
March 19, 20214 yr comment_618139 Lots of reasons or guesses here. https://www.zcar.com/threads/is-the-oil-slinger-needed-or-not.71194/ Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618139 Share on other sites More sharing options...
March 19, 20214 yr comment_618146 It's called an "oil thrower". Link to comment https://www.classiczcars.com/forums/topic/65190-woodruff-key-disappeared-into-the-abyss/#findComment-618146 Share on other sites More sharing options...
