New to me ‘75 280z. It has less than 60k miles. It was driven infrequently for the last 15-20 years. Drained the full tank and the gas at the bottom was very old and dark. Car starts fine when it’s cold. Runs well. Idle is the tiniest bit rough but holds. The issue is hot start. It will stutter on cranking and take longer to start. Then it barely runs and sounds like it’s running on less than 6 cylinders. I have to hold down the gas pedal and it will miss and buck for a few seconds. Then it clears up and runs ok. I can drive it normally and it will idle. It has new air and fuel filters, plugs, wires, points and distributor cap. I’m going to throw in a can of Techron today, but thought I’d post here. Searched and found plenty of cold start threads but no obvious hot start ones.
https://www.classiczcars.com/forums/topic/65191-hot-start-issue/Share on other sites
