20 minutes ago, Zed Head said:
Looks like a worn clutch or wrong throwout bearing sleeve/collar.  The fork seems to be hitting the back of the bellhousing hole.  I think I can even see a mark.
Clutch is new some cheap power torque from O’reilys. Had a feeling that it was the issue. Looks like I’m going to have to remove the transmission yet again 😞
It's a very common problem.  There is a multitude of pressure plate and throwout sleeve combinations.  Tall, short, and in-between.  The cheap clutch is probably fine, it's the combination of parts that is the problem.
Can he not run the threaded rod out some more? Looks like he has some threads on the back side.
I’ll max it out and see if it has any affect.
I think the fork is hitting the back of the hole at the end of the stroke.  He might have a bit more but it doesn't look right.  Should be more centered.
Looks like your observation is correct. I don’t have a helper at the moment so this is the clutch at resting
