My comment about getting rid of factor fuel rail and injectors had to do with the car has 1983 injectors in it and the factory rail has rust in it from it setting 16 years or so. Three injectors spray decent and the other 3 are barely squirting. The seals are yuk as well. I’ve got 38 psi at the rail prior to the regulator. I also checked the cold start valve per the FSM from Xenon. The engine is tough on this car despite the body being pristine. I appreciate all the comments and help.
scott
Zed Head, the fuel is new 99 octane leaded fuel and I pulled tank and completely cleaned it correctly and the pickup and sending unit.
scott
Seems like you have your solution, that's a lot of years, especially in a rainy humid part of the planet.  Might as well jam the brake pedal a few times to go ahead and blow the seals in the master cylinder.  Do the clutch too.
Interesting you mention that! The secondary clutch cylinder blew when we rolled it off the trailer. The master cylinder is corroded bad as it attaches to power booster. My 82 had to have all that replaced as well as shocks and struts.
Scott
