April 12, 20213 yr Author comment_619663 I would say for a 51-year old wrap it looks pretty darn good. Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619663 Share on other sites More sharing options...
April 13, 20213 yr comment_619671 On 4/11/2021 at 7:39 AM, Zeeguy62 said: I have the original clamps but did not want to possibly scratch the paint while installing! The steering wheel cover was a factory authorized option in 70 and was installed by the dealer. The steering wheel cover looks good. Interesting. Its just that back in the 1970's I never saw a 240Z with a steering wheel cover installed. They are more common now. I worked in a Datsun dealership parts department and there was no Datsun supplied steering wheel option offered I ever saw. Edited April 13, 20213 yr by gundee Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619671 Share on other sites More sharing options...
April 14, 20213 yr comment_619790 Why do people pump the accelerator before cranking the engine on a Z? There are no accelerator pumps in the carbs, so it does nothing. Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619790 Share on other sites More sharing options...
April 14, 20213 yr comment_619792 They do the same on EFI 280s. Nuckin futs. Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619792 Share on other sites More sharing options...
April 14, 20213 yr comment_619793 Older people do it because they grew up with carbs that had accelerator pumps and automatic chokes that didn't work very well when they got old. Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619793 Share on other sites More sharing options...
April 14, 20213 yr Author comment_619794 When the car is just started and the choke is still on, it is habit to just give it a little extra gas. Too many different old cars to change habits! Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619794 Share on other sites More sharing options...
April 14, 20213 yr comment_619795 So how do you start your 240Z? For 48 years on a cold engine start I pull the choke, hold the pedal to the floor and crank. Generally it fires within 4 seconds. On a warm engine I just have to touch the key and it starts right up. Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619795 Share on other sites More sharing options...
April 14, 20213 yr Author comment_619796 The guy that did the video for me Manages the facility and deals with over 100 different cars. I am sure there are many where an extra push on the gas pedal helps. Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619796 Share on other sites More sharing options...
April 14, 20213 yr Author comment_619797 I start it like you. Choke it, hold accelerator down and fire it. But then again, I lived in Ohio before coming to Florida and Texas. I used the choke about half the year! Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619797 Share on other sites More sharing options...
April 14, 20213 yr comment_619800 19 minutes ago, w3wilkes said: So how do you start your 240Z? For 48 years on a cold engine start I pull the choke, hold the pedal to the floor and crank. Generally it fires within 4 seconds. On a warm engine I just have to touch the key and it starts right up. For my 72 240 street car, and the 71 240 race car: If a cold start, I set the choke, crank the key. If it doesn't fire right up I press the pedal down a bit, but not wide open. A cold start needs a rich mixture, so wide open leans it out. For a warm start I just crank it up. For the 75 280, and the 79 280ZX, I cranked, cold or hot, without touching anything but the key. They always fired right up. (Both cars have been parked out back for about 20 years, so who knows what they would do today. ) Edited April 14, 20213 yr by Racer X Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619800 Share on other sites More sharing options...
April 16, 20213 yr comment_619894 Regarding starting your 240Z here's a snippet from the 1970 owner's manual: Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619894 Share on other sites More sharing options...
April 18, 20213 yr comment_619979 On 4/16/2021 at 8:14 PM, CanTechZ said: Regarding starting your 240Z here's a snippet from the 1970 owner's manual: That's not correct then. The acc pedal only controles the butterfly valve, nothing more. So basically you control the " air valve ". The throttle valve is vacuum operated. Link to comment https://www.classiczcars.com/forums/topic/65269-1970-240z-survivor-on-hemmings-auctions/?&page=2#findComment-619979 Share on other sites More sharing options...
