If they really are NOS then I would wash them well with either hot soapy water or wax & grease remover, give them a light scuff with Scotch pad or 400 grit and paint them.
I might strip them if it is an uncatalyzed paint. If it doesn't come off with lacquer thinner, then I would do like Grannyknot suggested
Thanks guys...I'll try thinner on them. Were in their boxes since the 1970/80s. Owner passed away and they were never fitted to a car. Saves me doing bodywork straightening the ones on my car out.
  • Mike changed the title to Just picked up a couple of new old stock 240Z fenders/wings
I would go back to metal forsure!  My painter (pro) advised to go to metal because you would be working on a very old surface and you don't know what it's going to do with the new paint chemicaly..
I would not gamble!  take it off!
Use a 60 sandpaper on a rotary it go's fast.  other painters say do not use chemical stuff to get it of because you have to clean it very well and then still you find it back in the new paint.. they say.. 🙄
Edited by dutchzcarguy
Agreed take them down to metal. Where did you find them? I need the same parts as I’m sure every S30 owner does.
Edited by SurferD
