If I were in the middle of the outback and needed to get to the hospital, I might try swapping the cap from one motor to another just to save a life. But I would never expect it to last.
And I certainly would never try that on cap #4 or the rear cap #7.
So unless the guy you bought the motor from turns up the missing cap, it sounds like you bought a paperweight.
Well I'm not sure what everyone here is talking about when they suggest line-boring, but where I come from, it would mean putting all the caps into place at spec torque, and then running a cutter through to remove material thereby making sure all the journals all perfectly in-line and the same size.
But my question is... What then? You'll need larger bearings with more meat on the outside to make up for the material you took off. You got a source for that?
You can get "oversized bearings" with more meat on them on the INSIDE for when the crank is ground, but to find bearings with more meat on the OUTSIDE that were designed to fit into a larger block bore? I mean... I've never looked. Is that a thing?
  On 4/20/2021 at 7:38 AM, jonbill said:
But I'd think just buying a complete l28 block would be easier and cheaper.
I think that the caps are considered part of the engine block.  Not shown as available as separate pieces.  A guy could probably go to a wrecking yard and find one then have a machinist make it work.  But, it's still going to come from a used engine.
I'd have the guy search his garage for that cap.
http://www.carpartsmanual.com/datsun/Z-1969-1978/engine-280z/cylinder-block
For the record though, you can buy main caps for a Chevy small block from numerous places.
You might call somebody like Datsun Spirit or Arizona Z Car, if you decide to try to save the block.  They build engines.  Might even have some used ones.
https://www.jegs.com/i/Speedmaster/746/PCE289.1002/10002/-1?gclid=Cj0KCQjw9_mDBhCGARIsAN3PaFNMd6jy7Ofu06P4cJsdCpPw58lu4UozC605W25FcJdrOXT8lkmMhT4aAjA4EALw_wcB
https://datsunspirit.com/
http://arizonazcar.com/
