Posted April 20, 20213 yr comment_620166 Hello, I have a 1973 Datsun 240z, I had the turn signal assembly refurbished and when reinstalling it the horn will no longer work. I noticed the copper arm on front of the assembly so when I press that on the back of the steering wheel the horn works. If I rest it on the back of the steering wheel the horn blares constantly, if I press the center of the steering wheel or not. I assume it is something simple and I am just a noob but I don't know. Any suggestions? Link to comment https://www.classiczcars.com/forums/topic/65294-stock-240z-horn-is-constantly-on/ Share on other sites More sharing options...
April 20, 20213 yr comment_620168 Adjust the arm so that it is in contact with the back of the horn button when the horn button is pushed in. If it is resting against the horn button, you have completed the circuit, and the horn will blow constantly. Link to comment https://www.classiczcars.com/forums/topic/65294-stock-240z-horn-is-constantly-on/#findComment-620168 Share on other sites More sharing options...
April 21, 20213 yr comment_620208 14 hours ago, SteveJ said: the horn will blow constantly. That BLOWS... 😂 Link to comment https://www.classiczcars.com/forums/topic/65294-stock-240z-horn-is-constantly-on/#findComment-620208 Share on other sites More sharing options...
April 21, 20213 yr comment_620217 That BLOWS... [emoji23]And we’re back in the playground again, aged 12! Link to comment https://www.classiczcars.com/forums/topic/65294-stock-240z-horn-is-constantly-on/#findComment-620217 Share on other sites More sharing options...
April 22, 20213 yr comment_620252 19 hours ago, AK260 said: Duplicated post by Tapatalk! btw, you know there is a hide button? (under the tripple points in the right. only by your own message that is..) It happens when you doubbleclick i think? never did that.. 😐 Link to comment https://www.classiczcars.com/forums/topic/65294-stock-240z-horn-is-constantly-on/#findComment-620252 Share on other sites More sharing options...
April 22, 20213 yr comment_620282 9 hours ago, dutchzcarguy said: btw, you know there is a hide button? (under the tripple points in the right. only by your own message that is..) It happens when you doubbleclick i think? never did that.. 😐 Thank you! It worked! But I don't have that option on tapatalk, only on internet! 😞 Link to comment https://www.classiczcars.com/forums/topic/65294-stock-240z-horn-is-constantly-on/#findComment-620282 Share on other sites More sharing options...
April 22, 20213 yr comment_620286 Another good thing about going to the site on your phones web browser. I "HIDE" stuff all the time. Almost as much as I drink and post. Link to comment https://www.classiczcars.com/forums/topic/65294-stock-240z-horn-is-constantly-on/#findComment-620286 Share on other sites More sharing options...
