Posted May 1, 20213 yr comment_620899 Hey guys so after trying to get my 260z with Weber 32/36 carbs set up(which I just rebuilt) I finally got it running today! It’s not running too good though haha. When I started it up it was idling at about 5k rpm! I tightened the idle mixture screws a bit and got it down to 3k rpm, obviously better but still really high. Another strange thing is when I turn off the car, it almost keeps running but dies slowly and starts blowing some white smoke from the top of the carbs. If I want to kill it right away as soon as I turn it off, I floor it to open the throttle valves and it shuts down smoothly. A couple things that I think may be causing these issues and wanted to get your opinions; number 1 that the throttle valves aren’t closed completely and they are staying a bit open and letting too much gas into the engine at idle. The reason I think this is that when I filled the carbs with some gas to get it running originally I noticed that the primary valve was not holding any of the gas I was pouring number 2, that my floats could be too high, I switched the brass ones to plastic and reset the heigh to 35 mm, but maybe I made a mistake here? number 3 honestly not too confident in this one but it may be caused by somehow getting too much fuel from the mechanical fuel pump? number 4, other possible area where the carbs could be having an air leak. Just a quick note as well: my carbs don’t have the choke plates installed, the previous owner welded the choke shaft’s holes shut any help is greatly appreciated, and if there’s any info I can add please let me know! Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/ Share on other sites More sharing options...
May 1, 20213 yr comment_620901 Who is the resident Weber 32/36 wizard on here? 🧙♂️ The issue of the motor that still running after the ignition being off can be from having too much fuel in the system. This also might be linked to issue # 1 from your post. It seems like the state of the carb might mean it needs to be repaired. For the reasons 1 and 4. (air leaks can be checked by shooting carb cleaner at the car while the motor is on, and listen for a change in RPM) I think Weber 32/36 need 3/5 psi of fuel (from what a reference manual says online) the OEM SU carbs use 4-6 PSI if i recall correctly. Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620901 Share on other sites More sharing options...
May 1, 20213 yr Author comment_620902 52 minutes ago, heyitsrama said: Who is the resident Weber 32/36 wizard on here? 🧙♂️ The issue of the motor that still running after the ignition being off can be from having too much fuel in the system. This also might be linked to issue # 1 from your post. It seems like the state of the carb might mean it needs to be repaired. For the reasons 1 and 4. (air leaks can be checked by shooting carb cleaner at the car while the motor is on, and listen for a change in RPM) I think Weber 32/36 need 3/5 psi of fuel (from what a reference manual says online) the OEM SU carbs use 4-6 PSI if i recall correctly. Thanks for answering man, there’s no way That originally pouring fuel into the carbs should be causing the motor running after turning it off right? I just rebuilt the carbs and everything was functioning and sliding properly when I manually tested them regarding the PSI, since the 260z had both an electric and mechanical pump is the system getting too much gas? And even if that Is the case, isn’t the point of the float to limit the amount of gas ? I’ll give the carb cleaner in the carb while running a shot and hope that works. I was able to get it down to about 2500 rpm after tightening the idle mixture screw down but that’s still a ridiculous idle especially with the car being manual Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620902 Share on other sites More sharing options...
May 1, 20213 yr Author comment_620904 1 hour ago, heyitsrama said: Who is the resident Weber 32/36 wizard on here? 🧙♂️ The issue of the motor that still running after the ignition being off can be from having too much fuel in the system. This also might be linked to issue # 1 from your post. It seems like the state of the carb might mean it needs to be repaired. For the reasons 1 and 4. (air leaks can be checked by shooting carb cleaner at the car while the motor is on, and listen for a change in RPM) I think Weber 32/36 need 3/5 psi of fuel (from what a reference manual says online) the OEM SU carbs use 4-6 PSI if i recall correctly. Quick note to add that I’d love to ask you about, I don’t have a fuel return line, the previous owner removed it. Do you think this could be causing my issue?? Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620904 Share on other sites More sharing options...
May 1, 20213 yr comment_620905 Engine RPM is controlled by air flow. So high RPM means that you have uncontrolled air getting in somewhere. If it's idling at 3000 RPM and you already have extra gasoline then carb cleaner might not show you much. Engine running after ignition off is usually from hot spots in the combustion chamber. Often caused by carbon deposits from running rich. When you floor it before shutting down you let a blast of cool air and gasoline in and kill the hot spots. The throttle blades control air flow not gasoline. They need to shut completely if you want to control your idle speed. Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620905 Share on other sites More sharing options...
May 1, 20213 yr Author comment_620906 8 minutes ago, Zed Head said: Engine RPM is controlled by air flow. So high RPM means that you have uncontrolled air getting in somewhere. If it's idling at 3000 RPM and you already have extra gasoline then carb cleaner might not show you much. Engine running after ignition off is usually from hot spots in the combustion chamber. Often caused by carbon deposits from running rich. When you floor it before shutting down you let a blast of cool air and gasoline in and kill the hot spots. The throttle blades control air flow not gasoline. They need to shut completely if you want to control your idle speed. Thank you @Zed Head, so what do you think the problem could be? Could it be running rich due to too much fuel pressure? Should I try installing a regulator? also could the fact that I don’t have a choke be causing the issue? I’m sorry if my questions aren’t advanced,I literally just started learning about carbs and how they work about a week ago. Thanks for your time Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620906 Share on other sites More sharing options...
May 1, 20213 yr Author comment_620909 Hey guys I also just realized that my throttle stop is sitting really far forward after installing the carbs, compared to when I had them out of the car. I wish I I had a picture right now but I work on the car at a lot an hour away. Basically even with the idle speed screw screwed in all the way it doesn’t touch the throttle stop. Could I have just bolted it down too far forward by accident? Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620909 Share on other sites More sharing options...
May 1, 20213 yr comment_620911 Make sure these flats are in the right order. I put mine back on wrong and it shot up to 2 or 3 thousand rpms. Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620911 Share on other sites More sharing options...
May 1, 20213 yr comment_620913 So first thing, do not overtighten any mixture screws in a Weber carb!! You can damage the seats in the carb... The white smoke coming out of the carb might be atomized fuel Remove the any linkage from the gas pedal and see if the butterflies will close any more. Also an small inline fuel pressure gage can be very helpful Do these carbs have any electrical solenoids on them? I believe some of these carbs had anti dieseling solenoids on them Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620913 Share on other sites More sharing options...
May 1, 20213 yr comment_620916 28 minutes ago, siteunseen said: Make sure these flats are in the right order. I put mine back on wrong and it shot up to 2 or 3 thousand rpms. Oh crap I did it again. Y'all are talking about Webers and I started reading at the last post. I'm sorry. Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620916 Share on other sites More sharing options...
May 1, 20213 yr Author comment_620919 34 minutes ago, Patcon said: So first thing, do not overtighten any mixture screws in a Weber carb!! You can damage the seats in the carb... The white smoke coming out of the carb might be atomized fuel Remove the any linkage from the gas pedal and see if the butterflies will close any more. Also an small inline fuel pressure gage can be very helpful Do these carbs have any electrical solenoids on them? I believe some of these carbs had anti dieseling solenoids on them Okay I’ll loosen up the screws to not damage the carbs, I didn’t over tighten, I had seated them and turned them two full turns out, but while adjusting I tightened it in one more term. I believe the smoke coming out is run on(dieseling) from excess fuel. I’m going to borrow a fuel pressure test from autozone and see what I can figure out tomorrow. I’ll also unhook the gas pedal linkage and see if I can get the throttle stop to sit more forward as that may be part of my problem. no I don’t believe there’s any electrical solenoids on them Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620919 Share on other sites More sharing options...
May 2, 20213 yr comment_620920 Let us know what you get Link to comment https://www.classiczcars.com/forums/topic/65336-engine-idling-at-3k-rpm-i-think-i%E2%80%99m-getting-too-much-fuel-from-the-carbs/#findComment-620920 Share on other sites More sharing options...
