May 15, 20213 yr comment_621627 Found my old thread. Tip: One thing I did not mention in that thread was the outer ring where the rollers run against. It is not a perfect donut form, but the inner circle is a little off center. Very important to note it's position before dismantling. There is a small notch on the outside to help, but it doesn't have any corresponding marks on the housing. Position it wrong and itwill reduce the pump performance considerably. Mine couldn't reach 35 psi until I tried another position. Edited May 15, 20213 yr by EuroDat Tip of the day Link to comment https://www.classiczcars.com/forums/topic/65376-efi-fuel-pump-noise/?&page=2#findComment-621627 Share on other sites More sharing options...
May 15, 20213 yr comment_621630 8 hours ago, wheee! said: I remember testing it years ago and It wasn’t noisy on the bench. I hope you tested it with fuel.. these pumps fail when you run them without fuel longer then a few seconds.. (if you look on youtube , bosch fuelpump 044 there are some info's around knock off's .. wow..) Link to comment https://www.classiczcars.com/forums/topic/65376-efi-fuel-pump-noise/?&page=2#findComment-621630 Share on other sites More sharing options...
May 15, 20213 yr comment_621637 Mine gets noisy when it’s hot outside Link to comment https://www.classiczcars.com/forums/topic/65376-efi-fuel-pump-noise/?&page=2#findComment-621637 Share on other sites More sharing options...
May 15, 20213 yr Author comment_621639 I hope you tested it with fuel.. these pumps fail when you run them without fuel longer then a few seconds.. (if you look on youtube , bosch fuelpump 044 there are some info's around knock off's .. wow..)I tested the blue hitachi with fuel before I bought the original black Bosch with the new fuel tank. I can’t remember testing the pump but I remember the seller saying it ran perfect before he pulled it. It was in very good condition. Link to comment https://www.classiczcars.com/forums/topic/65376-efi-fuel-pump-noise/?&page=2#findComment-621639 Share on other sites More sharing options...
May 16, 20213 yr comment_621676 19 hours ago, wheee! said: I tested the blue hitachi with fuel before I bought the original black Bosch with the new fuel tank. I can’t remember testing the pump but I remember the seller saying it ran perfect before he pulled it. It was in very good condition. The early 280Z all had Bosch components in the EFI. They progressively changed over to JECS and Hitachi in the years after. First to go was the Bosch ECU in April 75 and the AAR, AFM & Fuel injectors followed that year. I think the fuel pump might be the last of the EFI components to move. Most EFI parts where then JECS and some JECS' parent company Hitachi. Approx. Fuel pump time line Bosch up to mid. 76. Hitachi N4200 & N4700 (black terminals) up to Sep 77 Hitachi N4205 (blue terminals) from Oct 77. The inlet filters and internal pump components from the N4200 & N4700 don't fit the N4205. The filters and pump rollers are different lengths. The o-rings including the motor house o-ring will fit all 3 version and the inlet house and complete pump sections are interchangable so you can swap a pump to another motor etc. Link to comment https://www.classiczcars.com/forums/topic/65376-efi-fuel-pump-noise/?&page=2#findComment-621676 Share on other sites More sharing options...
May 16, 20213 yr comment_621680 I got one of the last Bosch pumps in 2011 or 2012 from Advance Auto, $250. Then Beck Arnley started making them if I remember right. Link to comment https://www.classiczcars.com/forums/topic/65376-efi-fuel-pump-noise/?&page=2#findComment-621680 Share on other sites More sharing options...
