Hello,
I just bought the 280Z, I have not got the car yet, it is coming this week hopefully. Anyway, someone broke into the car through the passenger side quater window. They didn't break the glass, they just damaged the seal. How can I fix that? Do I need to buy the glass and the seal? or the seal should work? What other stuff do I need to buy?
Thank you,appreciated
Viz
https://www.classiczcars.com/forums/topic/6538-how-to-fix-the-quater-window/
If you are referring to the seal that is on the front edge of the quarter window, those are available yet. That is the seal that the door's stainless window frame seals to. If on the other hand you are referring to the seal that the quarter window is housed in, those are usually available in pairs.
Hope this helps.
Enrique
