Posted May 15, 20213 yr comment_621658 I got the scales out before taking the 510 off the rotisserie, front weighed in at 295lbs, the rear at 293lbs equaling 588lbs, minus both of the stripped doors at 40lbs a piece and 32lbs for the rotisserie mounts. So total stripped weight for a 73/2dr 510 comes out at 476lbs. Link to comment https://www.classiczcars.com/forums/topic/65386-510-weighed/ Share on other sites More sharing options...
May 15, 20213 yr comment_621660 Sorry for not reading back, but did you did you end up with an SR 20 or a KA24DE? Link to comment https://www.classiczcars.com/forums/topic/65386-510-weighed/#findComment-621660 Share on other sites More sharing options...
May 16, 20213 yr Author comment_621667 On 5/15/2021 at 10:59 PM, Reptoid Overlords said: Sorry for not reading back, but did you did you end up with an SR 20 or a KA24DE? Well, the car came with an SR20 but it was in pretty bad shape so traded it straight across for a KA24DE. Link to comment https://www.classiczcars.com/forums/topic/65386-510-weighed/#findComment-621667 Share on other sites More sharing options...
May 16, 20213 yr comment_621669 Right. At any rate they are pretty light, maybe 350lbs? Do you have a target weight you hope to achieve? Or just a light as possible while still retaining all items to keep it a livable road car? Link to comment https://www.classiczcars.com/forums/topic/65386-510-weighed/#findComment-621669 Share on other sites More sharing options...
May 16, 20213 yr Author comment_621675 On 5/16/2021 at 2:01 AM, Reptoid Overlords said: Right. At any rate they are pretty light, maybe 350lbs? Do you have a target weight you hope to achieve? Or just a light as possible while still retaining all items to keep it a livable road car? I will have the KA engine on the hoist in a few days and will post a definitive weight then, but yes not much heavier than the original engine with an additional 65hp. I don't have a target weight, it's not going to be a track car and I will be adding some sound/ heat baffling and comfortable seats. The battery is being repositioned to the P/S trunk to help even out the load. Link to comment https://www.classiczcars.com/forums/topic/65386-510-weighed/#findComment-621675 Share on other sites More sharing options...
May 16, 20213 yr comment_621681 I can't recall: Did you do similar weight measurements for the 240Z? If so, what were the front and rear weights? And engine (or engine + transmission)? Link to comment https://www.classiczcars.com/forums/topic/65386-510-weighed/#findComment-621681 Share on other sites More sharing options...
May 16, 20213 yr Author comment_621693 On 5/16/2021 at 3:02 PM, Namerow said: I can't recall: Did you do similar weight measurements for the 240Z? If so, what were the front and rear weights? And engine (or engine + transmission)? I didn't own a scale when I did the 240 but I weighted the 280 a couple of years ago and the stripped shell was 530lbs so the 240 is probably close to 500lbs. A bare bones L28 engine is 304lbs and with the 5speed attached they weigh in at 435lb. Link to comment https://www.classiczcars.com/forums/topic/65386-510-weighed/#findComment-621693 Share on other sites More sharing options...
