I'm making some progress on getting this beautiful car back on the road.  But I did make one mistake.  I had to take the gas tank out and to do so I cut the rubber filler neck, it's shaped like an elbow and connects directly to the tank.  I've been to many web sites including vintage Z car parts(they tried to help me but we came up short.)  Solid suggestions greatly appreciated.
I just checked the link that Steve J posted in your other thread.
I think a 90 degree elbow of the right size should work.
https://www.fillernecksupply.com/fuel-hose-elbows/
Lots of progress this weekend.  First off I'm told the best replacement filler neck is from Gates Auto part #24717.  This Sunday I put the fuel pick up line into a can of clean gas and put the fuel line from just before the filter into another empty can.  Then I turned the ignition to on which started the fuel pump, and pushed all of the old gas out of the line.  Then at the back of the car I put the return fuel line in a empty can and started the car.  It idled pretty good for a car that hasn't run in 10-20 years.  The motor sounded a little ticky for me but I don't know what it's suppose to sound like.
A valve lash adjustment probably won't hurt.  The valve trains on these cars are a little noisy when compared to modern hydraulic lifters.  Some more so than others from what it seems.
The fuel injectors are a little noisy by nature as well.
Mine is a little noisier now that I have a header, plus my exhaust isn't totally welded up yet.
Post a video of it idling if you can. Someone will let you know if it's abnormal.
Edited by Reptoid Overlords
