I'm making some progress on getting this beautiful car back on the road.  But I did make one mistake.  I had to take the gas tank out and to do so I cut the rubber filler neck, it's shaped like an elbow and connects directly to the tank.  I've been to many web sites including vintage Z car parts(they tried to help me but we came up short.)  Solid suggestions greatly appreciated.
Lots of progress this weekend.  First off I'm told the best replacement filler neck is from Gates Auto part #24717.  This Sunday I put the fuel pick up line into a can of clean gas and put the fuel line from just before the filter into another empty can.  Then I turned the ignition to on which started the fuel pump, and pushed all of the old gas out of the line.  Then at the back of the car I put the return fuel line in a empty can and started the car.  It idled pretty good for a car that hasn't run in 10-20 years.  The motor sounded a little ticky for me but I don't know what it's suppose to sound like.
A valve lash adjustment probably won't hurt.  The valve trains on these cars are a little noisy when compared to modern hydraulic lifters.  Some more so than others from what it seems.
The fuel injectors are a little noisy by nature as well.
Mine is a little noisier now that I have a header, plus my exhaust isn't totally welded up yet.
Post a video of it idling if you can. Someone will let you know if it's abnormal.
Edited by Reptoid Overlords
