Posted May 27, 20213 yr comment_622249 I tried to install a pilot bushing into an l24, but the bushing was too big to fit. From what I’ve found, the l26 and l24 use the same pilot bushing, but the bushing that came with my clutch kit doesn’t fit my l24, but does appear to fit my l26 (the l26 still has the pilot bushing in it, but the new one appears to be the same size.) If someone can tell me what’s wrong with this picture, I’d very much appreciate that! I’d like to drive my Z again! I measured the pilot bushing and the end of the l24 crankshaft Incase it helps. Crankshaft id .783 inches Bushing od .813 inches Im pretty confident that there isn’t already a bushing in the end of the crank shaft, at least not one that looks like the bronze/brass replacement that I have. I’ll add a couple photos incase that helps also, maybe there is a bushing in there and I’m stupid. Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/ Share on other sites More sharing options...
May 27, 20213 yr comment_622250 i measured my spare od is the same as you have. is there a flange on the end of that crank? this is what the flywheel end looks like. Edited May 27, 20213 yr by heyitsrama Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/#findComment-622250 Share on other sites More sharing options...
May 27, 20213 yr Author comment_622251 @heyitsrama if you notice that sort of ridge on the end of the crankshaft, that is not present on my l26. I’m not sure if that’s something that comes off, or if it’s normal for an l24. I’m still learning about datsuns Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/#findComment-622251 Share on other sites More sharing options...
May 27, 20213 yr comment_622252 Was the l24 out of a automatic car? Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/#findComment-622252 Share on other sites More sharing options...
May 27, 20213 yr comment_622253 IIRC All the pilot bearings are the same for any l-series motor (it was also used on other motors too) I think you have something mated to the back end of the crank, it might need to be removed in the same manor as a pilot bearing if it is installed within the pilot bearing hole. My preferred way to remove pilot bearings is to pack it with grease, then push the grease out using a solid rod of steel and a hammer. You really have to put pressure on the grease to get it to push out the bearing. See these layers before the threads? Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/#findComment-622253 Share on other sites More sharing options...
May 27, 20213 yr Author comment_622254 i don’t know for sure but I think the l24 might’ve come from an automatic car. There’s a hardline running along the drivers side of the engine that isn’t actually running to or from the engine. Looks like it could be a transmission cooler line for an automatic. Not sure if Zs had transmission coolers or not. Ill see if that piece on the end of the crankshaft will come off, tomorrow. Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/#findComment-622254 Share on other sites More sharing options...
May 27, 20213 yr comment_622255 That crank does have an auto adapter on the back there. It shouldn't be there on a manual gearbox. They can be quite firmly attached, but it will pry off. Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/#findComment-622255 Share on other sites More sharing options...
May 27, 20213 yr comment_622267 Agreed that’s the flex plate adapter. Should slide off the crank. Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/#findComment-622267 Share on other sites More sharing options...
May 27, 20213 yr comment_622275 How are you trying to remove the old bushing? Do you have a pilot shaft bushing puller? It's the proffessional way to remove what's in there. EZPEEZE ! Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/#findComment-622275 Share on other sites More sharing options...
May 27, 20213 yr comment_622279 Doesn’t appear there was ever a pilot bushing there. Work that hub off of there and install your bushing. Careful not to drive the bushing in too far. I made that mistake and had to remove it and reinstall another one. The FSM shows you the proper depth. Same with the rear main seal. Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/#findComment-622279 Share on other sites More sharing options...
May 27, 20213 yr Author comment_622285 Thanks everyone, I got the automatic adapter off and can now proceed! Edited May 27, 20213 yr by Cooper260z Link to comment https://www.classiczcars.com/forums/topic/65426-pilot-bushing-troubles/#findComment-622285 Share on other sites More sharing options...
