May 31, 20213 yr Author comment_622459 On 5/31/2021 at 5:19 PM, Zed Head said: There's a 120 and and a 121. The 121 says "Jetronic", the 120 doesn't. Wonder if diodes/resistors is the difference. I know that their typical 5 pin relays come in different flavors. Same basic functions, just some have a few extra parts inside. Usually they show it on the cover, but these don't. https://www.amazon.com/Bosch-0332514121-BOS0332514121/dp/B006NYJ328 https://www.amazon.com/Bosch-Automotive-0332514120-Relay/dp/B004Z0W1C6 The pinouts on that 121 don't seem to match up, maybe a later year revision? Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622459 Share on other sites More sharing options...
May 31, 20213 yr comment_622461 Different cars, for sure. The 120 is the one you want, apparently. I wonder which Ford used it. Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622461 Share on other sites More sharing options...
May 31, 20213 yr comment_622462 Only real way to compare is to open the Bosch relay.. just my opinion. Would be great info for others if you're willing to sacrifice a good relay. 😉 Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622462 Share on other sites More sharing options...
May 31, 20213 yr comment_622467 Some work with a meter and a battery, should do the job. Measure resistance and direction. A fun project. Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622467 Share on other sites More sharing options...
May 31, 20213 yr comment_622470 On 5/31/2021 at 7:04 PM, Zed Head said: Some work with a meter and a battery, should do the job. Measure resistance and direction. A fun project. Exactly. Does anybody have a spare Bosch relay they want to send me for testing? Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622470 Share on other sites More sharing options...
May 31, 20213 yr comment_622476 Having parted a few BMW's I have quite a collection of Bosch relays, what kind do you want? Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622476 Share on other sites More sharing options...
May 31, 20213 yr comment_622477 On 5/31/2021 at 9:58 PM, grannyknot said: Having parted a few BMW's I have quite a collection of Bosch relays, what kind do you want? Well, the intent was to test the EFI relay. Do you happen to have one of those that match the ones earlier in this thread? Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622477 Share on other sites More sharing options...
May 31, 20213 yr Author comment_622481 Just bought one, should be here this week. Will do some testing! Edited May 31, 20213 yr by kyle146 Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622481 Share on other sites More sharing options...
June 1, 20213 yr comment_622485 On 5/31/2021 at 10:54 PM, SteveJ said: Well, the intent was to test the EFI relay. Do you happen to have one of those that match the ones earlier in this thread? I think so, it's still attached to the wiring harness, I'll drag it out tomorrow. Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622485 Share on other sites More sharing options...
June 1, 20213 yr comment_622492 Yes, I believe with a power source and some crafty meter work, one could determine if those extra components are included with the Bosch unit. I suspect they are. Oh, and by the way... There are two diodes inside the assy (not just one), so I edited my post above. On 5/31/2021 at 3:14 PM, Patcon said: What are the ramifications of not having those components? Hmmm... I'd have to look into that, but I bet the ramifications are unpleasant. Probably not "light the car on fire" unpleasant, but maybe "fuel pump runs when it shouldn't" kind of unpleasant. If you want me to dig into it, let me know. Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622492 Share on other sites More sharing options...
June 1, 20213 yr comment_622494 I was asking the next Obvious question, sort of for posterity's sake Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622494 Share on other sites More sharing options...
June 1, 20213 yr comment_622495 LOL. Yeah, it kinda makes me wonder a little too. There have been people who have "constructed" a fuel injection relay out of two independent generic relays. I wonder if those people included those additional components. Link to comment https://www.classiczcars.com/forums/topic/65441-280z-bosch-relay-correlation-stock-relay-vs-porsche-relay/?&page=2#findComment-622495 Share on other sites More sharing options...
