1 hour ago, Shawninvancouver said:
what do i do here???
Leave the wires on the spark plugs.  Disconnect all of the wires from the distributor cap.  Reconnect the wires to the cap as shown in w3wilkes post #2.
Put the rotor back on and make sure it points to #1 when the ignition timing mark is between zero and 10 degrees.
