June 12, 20213 yr Author comment_623293 ok - i am just going to hook up the 280zx dizzy.. is it that easy - 2 wires ? 2 from coil to new dizzy? which wire is tach and where does it go? is that light blue on my coil - the tach? thanks Edited June 12, 20213 yr by Shawninvancouver Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623293 Share on other sites More sharing options...
June 12, 20213 yr comment_623299 I use a tool like this to check for spark. Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623299 Share on other sites More sharing options...
June 12, 20213 yr comment_623301 4 hours ago, Racer X said: I use a tool like this to check for spark. I use one like this. Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623301 Share on other sites More sharing options...
June 12, 20213 yr comment_623303 When checking for spark at the coil, this is what I did. And that was from a 280ZX distributor that had wobble in the shaft, so it didn't have the proper gap at the reluctor. Edited June 12, 20213 yr by SteveJ Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623303 Share on other sites More sharing options...
June 12, 20213 yr comment_623306 $2 at Harbor Freight or just about anywhere else. For working alone as I often do now days. You can position it so you see it from the drivers seat. Edited June 12, 20213 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623306 Share on other sites More sharing options...
June 12, 20213 yr Author comment_623307 Ok just need to know what’s gauge wire to use for wires from coil to new dizzy. and will this coil be ok.. Thanks. Edited June 12, 20213 yr by Shawninvancouver Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623307 Share on other sites More sharing options...
June 12, 20213 yr comment_623310 1 hour ago, Shawninvancouver said: Ok just need to know what’s gauge wire to use for wires from coil to new dizzy. and will this coil be ok.. Thanks. Use the wiring that is already on the car. And yes, that coil should be fine. Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623310 Share on other sites More sharing options...
June 13, 20213 yr Author comment_623345 CASE CLOSED - car RUNS!!!! new 280zx dizzy fixes the problem... took out electronic ignition unit and ballast... thanks for the help.. can i now start a new thread on how to tune it up and get it to run normal??? Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623345 Share on other sites More sharing options...
June 13, 20213 yr comment_623350 4 hours ago, Shawninvancouver said: CASE CLOSED - car RUNS!!!! new 280zx dizzy fixes the problem... took out electronic ignition unit and ballast... thanks for the help.. Congratulations. 4 hours ago, Shawninvancouver said: can i now start a new thread on how to tune it up and get it to run normal??? I dunno, can you? Edited June 13, 20213 yr by Racer X Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623350 Share on other sites More sharing options...
June 13, 20213 yr comment_623353 5 hours ago, Shawninvancouver said: can i now start a new thread on how to tune it up and get it to run normal??? Step 1: Buy one of these. https://www.amazon.com/Latest-Rage-5385730856-Carburetor-Airflow/dp/B00CMC57R0/ref=asc_df_B00CMC57R0/?tag=hyprod-20&linkCode=df0&hvadid=309898128610&hvpos=&hvnetw=g&hvrand=16754559533879517408&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012727&hvtargid=pla-568420224882&psc=1 Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623353 Share on other sites More sharing options...
June 13, 20213 yr comment_623358 1 hour ago, siteunseen said: Step 1: Buy one of these. https://www.amazon.com/Latest-Rage-5385730856-Carburetor-Airflow/dp/B00CMC57R0/ref=asc_df_B00CMC57R0/?tag=hyprod-20&linkCode=df0&hvadid=309898128610&hvpos=&hvnetw=g&hvrand=16754559533879517408&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012727&hvtargid=pla-568420224882&psc=1 I have one of those, never used it. There isn’t enough room between the carbs and strut tower. Someone gave me one of these: It is easy to use and allows enough room to be quick and accurate. Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623358 Share on other sites More sharing options...
June 13, 20213 yr comment_623360 Never an issue on my '72 with 2 SUs. I remove the air box completely. Took me a minute to figure out the hole on the side that allows air in. Mine was pegging out at first then I rotated it around to open up that hole and pull some outside air in. Then it was a lot easier to use. Link to comment https://www.classiczcars.com/forums/topic/65481-74-260z-distributor-on-wrong/?&page=10#findComment-623360 Share on other sites More sharing options...
