Most of my spares.  Note that the ones which are dull grey are newer oem ones with the hex head.  However, I have many here with the correct pan head and those screws can be swapped.  Left-most are too big in diameter or wrong style.  I need to know what diameter you are looking for specifically.
The two gold ones are the newer style with hex heads, but I believe I have the proper screws in the right size to swap to those clamps.  The four grey ones in the second column from the right look about right for the radiator, and I know I have the proper screws for those.
You would need to send these off for re-plating in zinc (clear - which is silver in color) if you want them to look like factory.
  • 3 weeks later...
Wondering if Inline or anyone else knows which other clamps are clear zinc plated.
I think my valve cover vent hose clamps were but I’m not positive they were original. Possibly the PCV ones too but they are very hard to tell because of their age.
Edit: I guess these could have changed through the years too, mine is a 79
