Finally going to redo my exhaust to gain clearance - remove resonators , add performance cat , and all new pipe from to back to front
Besides the awkward and painful positions to do exhausts without a 6ft lift , I kind of enjoy crafting an exhaust system .
I just buy and bunch of mandrel bends and pie cut what I need . Dual 2” gets tight :-0
Starting the first leg getting to the cat .
Might challenge myself to TIG it
Edited by madkaw
https://www.classiczcars.com/forums/topic/65499-duals-do-over/
13 hours ago, munters said:
That's an interesting one.
Will the Performance cat act like a resonator (do you hope that)? Do you have in mind to use 2 lambda sensors? I'm curious about the autcom. Could be also something for me.
Been running two Lamba’s . The cat is for smell, convenient packaging for two pipes .
Well this is going to be a slower process then anticipated. My spool gun is giving me fits and has forced me to actually learn how to TIG . I guess no time like the present to teach an old dog a new trick . I have played around with TIG, but I’m a rookie for sure . With a bad back I couldn’t refill my CO2 tank and the Argon tank was about full, so....
Almost have the first legs of the exhaust  to the cat done ,which was going to be the hard part . I think I gained about an inch in ground clearance or maybe more . Got to get this right , because this will be the last time
