September 2, 20231 yr comment_656587 Have you tried the “old school hillbilly technique”? Just a blimish of white lithium grease on the Mc piston. Once you find evidence on the booster rod itself give it another 1/4 turn and you should be dead on. Link to comment https://www.classiczcars.com/forums/topic/65546-brake-booster-push-rod-adjustment/?&page=2#findComment-656587 Share on other sites More sharing options...
September 2, 20231 yr comment_656592 Do you have the rear shoes adjusted to spec. If out, they will eat up all your pressure before the fronts engage fully. Just an issue I ran across in my brake system. Link to comment https://www.classiczcars.com/forums/topic/65546-brake-booster-push-rod-adjustment/?&page=2#findComment-656592 Share on other sites More sharing options...
September 2, 20231 yr comment_656598 That's a good point. I had a similar problem when the front calipers were on the wrong sides. The pedal went halfway down before any brake action. My problem was air in the system though, that could not get out. Easy mistake to make. Bleed valve on top. Edited September 2, 20231 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/65546-brake-booster-push-rod-adjustment/?&page=2#findComment-656598 Share on other sites More sharing options...
September 2, 20231 yr comment_656610 Thanks guys for all the clues. A few follow up questions/findings: Yarb: I like your adjustment method. To clarify: I would put the lithium grease inside the hollowed-out section of the MC piston as far forward as possible. Adjust pushrod until it just touches the grease. Would I then turn the adjustment 1/4 turn. Do I turn it in or out? Terrapin Z: I did not follow the exact method for adjusting the rear brakes. Did it the old way adjusted them up until they locked up, then backed them off until there was a slight drag on them. Your suggestion makes a lot of sense. Regarding lack of pressure. I will readjust. Zed Head: Just went out to the shop to check the location of the bleeder plugs on the front calipers. They are at the bottom. Your info and rechecking the FSM, they should be on top. I'll correct that. Your description on pedal action is quite similar to the problem I am having. FYI: In addition to having the symptoms Zed Head described regarding pedal action, when the pedal it pushed as far as it will go, there is some braking action but neither the front or the rear brakes will lock up. I'll make the changes and let you know how it goes. Thanks again. Link to comment https://www.classiczcars.com/forums/topic/65546-brake-booster-push-rod-adjustment/?&page=2#findComment-656610 Share on other sites More sharing options...
September 2, 20231 yr comment_656611 If the bleed screws on the calipers are on the bottom, you will never get good brake pressure! Link to comment https://www.classiczcars.com/forums/topic/65546-brake-booster-push-rod-adjustment/?&page=2#findComment-656611 Share on other sites More sharing options...
September 2, 20231 yr comment_656618 Definitely swap the calipers! If you have the master cyl loose it wouldn’t hurt to check the depth. When I say apply grease I mean as little as possible. 1/4 turn longer. When you go to mount it you will know if it’s too tight. Long cue tip and a smidgen of grease at the base. I think you Will definitely find it’s the calipers being reversed. Link to comment https://www.classiczcars.com/forums/topic/65546-brake-booster-push-rod-adjustment/?&page=2#findComment-656618 Share on other sites More sharing options...
September 8, 20231 yr comment_656844 Success! I made all the changes we talked about, bled the system (again) and now have good pedal feel and brakes. I'm pretty sure, as you all suggested, the caliper issue was the key problem. Thanks for all your help....You Guys Rock! Link to comment https://www.classiczcars.com/forums/topic/65546-brake-booster-push-rod-adjustment/?&page=2#findComment-656844 Share on other sites More sharing options...
