As we all know, not all needs are answered by over-the-counter tools. As one example, my Z-friend Dieter Roth made his own special wrench for one particularly annoying Z job (halfshaft U-joint bolts, IIRC) by simply grinding off the excess metal from a standard open-end wrench so that it would fit inside the limited-clearance space.  For my own efforts, I've enjoyed constant use over the years from a 18" length of 1"-dia aluminum tubing (from a TV antenna mast) that I squashed one end of so that it would fit over the end of open-end and box-end wrenches to give extra leverage.
What's in your tool box?
When I need to stretch out a spring instead of pliers/vise grips, I use a wire like drop ceiling hanging wire. Sort of like a clothes hanger. Put the wire through the spring end and double it over for a pull handle and pull it out to the the set hole. Works great.
I love making tools and jigs.  My latest was a modification to the spindle pin puller I made.  Since I already had the puller, I made another sleeve and turned it into a rear outer bushing puller.  It made removing the OE bushings almost easy.
For a spring that are in a gearbox base plate i use a side cutting pliers, just cut halfway into it, your not gonna hurt it just stretch it.
The best made tool was a apparatus to grip the crank on a 300zx(tt) z32 for taking of the balancer (necassary when changing the timingbelt)  without taking everything of and the starter also to block the crank!  I block the crank with my own made tool that clicks into the holes in the balancer/pulley.
(It's a horizontal beam fits to the stabilizerbar and has two steel round "fingers" that go into the holes of the balancer.  simple but effective..  saves a lot of time, because you don't need to take the starter off!)
This is all really good stuff.  Hopefully, we'll end up with an inventory of, 'Why didn't I think of that?' items that will save others a lot of time, grief and/or money.  They might even inspire some new ideas.  Pictures help, if you've got them.
I think @zKars can fill 10 pages!
4 hours ago, 240260280 said:
Wheel bearing race drifts:
1" black iron pipe coupling (ground a tad smaller)
I wondered why I had a cast iron pipe fitting in my Z parts drawer! You told me about how that reducer would work, and it did. Thanks again. :beer:
Recently Browsing 0
