The coil is a step-up transformer. It is composed primarily of wire, insulation, and material to help dissipate heat. If the insulation breaks down, you would see a weaker spark or no spark.
Are you having a problem with your car? If so describe when it started and under what conditions.
  • 7tooZ changed the title to Coil Question
@SteveJ thanks for your reply.
Yesterday I was a returning home a 30 mile drive at freeway speeds 70-75. Stopped for gas, fillup tank, started up and headed the 2 mi home. About 3 blks from home it simply died. Turned over but wouldnt start. By the time i went bank to get it couple hours +/- started and ran rough (like the plugs were fouled) for 10-15 sec and then was fine. Your rely kind of fit my thoughts of "heat related". That coil could be 15
Yesterday I was a returning home, a 30 mile drive at freeway speeds 70-75. Stopped for gas, fill-up tank, started up and headed the 2 mi home. About 3 blks from home it simply died. Turned over but wouldnt start. By the time i went back to get it (couple hours +/-) it started and ran rough (like the plugs were fouled) for 10-15 sec and then was fine. Your rely kind of fit my thoughts of "heat related". That coil could be 15+ years old.
Many coils are oil filled for the heat dissipation media. You may see residue around the center post of the coil. Some auto manufacturers did vertical mounting of the coil to reduce the chance of losing the oil. However, the oil will break down as it ages, providing less heat removal.
Think pickup a new one just to be sure. I see Fireball must not be producing them any more. Any suggestions?
